BT Whole Home Wifi with PN
morgansbob
Re: BT Whole Home Wifi with PN
Thank you, I’ll give that a try
morgansbob
morgansbob
Thank you, the diagram gives me the confidence to give it a go
regards
morgansbob
Fixes: 374
@morgansbob - just a heads-up for you, as you are obviously new to this, but it helps to mention the poster you are replying to.
morgansbob
a bit more complex than mine but I appreciate your input.
regards
morgansbob
morgansbob
Jab 1
i have fixed the issue with advice from the group. How can I write the subject off to prevent other contributors giving up valuable time please
regards
morgansbob
Fixes: 374
@morgansbob Just don't bother replying any more, the topic will naturally fall down the board and your comment about it being 'fixed' will mean most people will ignore it.
