BT Call Guardian or Call Protect
thevicar
A current Plusnet subscriber (X) was once in BT. Upon changing to Plusnet the BT email was changed from @btinternet.com to @gmail.com. However X's BT land line number was retained.
An issue has emerged over BT Call Guardian. When another current BT subscriber (Y) who has @btinternet.com, BT Broadband and BT landline calls the Plusnet subscriber's BT landline X, Y's landline is blocked.
X's old email and password is long forgotten.
As X cannot now log onto BT is it possible for X to unblock Y's number through Plusnet?
3 REPLIES 3
Fixes: 480
Re: BT Call Guardian or Call Protect
@thevicar  Welcome to the forum.
I would assume that Y needs to sort this out with BT.
thevicar
Thanks Baldrick1. I've tried BT without success. Perhaps the BT person was unfamiliar with Call Protect issues. I'll try again later.
In the meantime is it possible for plusnet customer Y to interrogate CP settings via Plusnet. If so what would Y have to do?
Fixes: 480
@thevicar
All this X and Y stuff is very confusing. Trying to see through the mist, what I think you are saying is that despite what has gone on in the past, when Y, a BT customer tries to ring X a Plusnet customer, then something of Y's is cut off. Why has this got anything to do with Plusnet? If I interpret this correctly then Y or someone helping Y needs to contact BT.
As far as I know BT Call Guardian is a feature of BT phones if so it can be turned off using the phone settings. Plusnet call protect will only block calls that the Plusnet customer has black listed. That can also be controlled, do a Google search for Plusnet Call Protect Table for all the setting options.
It's got nothing to do with email adresses.
