Auto Import of pics not working ( NOW FIXED ! ! )
- Re: Auto Import of pics not working
- « Previous
- Next »
27-10-2010 5:04 PM
27-10-2010 6:20 PM
just a thought.... should I reboot the laptop to make the change in the registry? or does it happen "immediately" without any other action (save plugging in the device to see if it works?)
27-10-2010 6:31 PM
27-10-2010 6:53 PM
Because, that box (in the paragraph entitled.... "Image acquisition".... is the very box that I am missing... when I plug my camera in... so now I need to know where in the registry it is located, and the necessary corrections to the registry to fix it..
here is the layout and content of my "photo acquisition" folder...
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Photo Acquisition\Camera
Default REG_SZ (value not set)
Acquisition Flags REG_DWORD 0x00000029(41)
Filetemplateld REG-DWORD 0x00000000(0)
Foldertemplateld REG_DWORD 0x00000000(0)
Root Directory REG_SZ c:\users\digital camera downloads 2010
Is there likely to be another location for the "import pictures dialogue box" ? ?
any offers?
27-10-2010 8:18 PM
This is what Windows 7 Help & Support says:
"The AutoPlay options only appeared the first time I plugged in a device or inserted a disc.
How can I find them again, so I can choose a different action?
To see the options one time, right-click the device or drive, and then click Open Autoplay.
If the device isn’t plugged in, hold down Shift and plug in the device. You can also hold down Shift while inserting a disc to see the list of options."
27-10-2010 9:24 PM
I have checked the "autoplay" options, several times.... Start > control panel > Autoplay then check the types of device and options... which previously I said I had set at "Import pictures using windows"...
I have changed, and changed back again, registry keys , iaw the linky previously provided, but the CD player still does not Autoplay when inserting a cd.... (neither does the "import pictures........" work when inserting the camera lead.,..
As a point of interest, I double checked the registry settings against my wife`s Vista and they are the same on both machines, (except the actual picture destination folder)...
something is wrong with the AUTOPLAY settings in the registry, or elsewhere, which need to be re-set......
so I am still back at square one...
![Cry Cry](/html/@6B4B63041062049E874E6843927E9ADE/images/emoticons/cry.gif)
27-10-2010 11:02 PM
27-10-2010 11:10 PM
http://support.microsoft.com/kb/967715
Obviously you need to follow the instructions to enable rather than disable.
By the way, you managed to Export the entire registry to a single file but how would you get it back again? Wouldn't importing just augment your current registry with the old values? In it's normal form the registry is stored as multiple files.
28-10-2010 7:56 AM
28-10-2010 8:56 AM
Thanks for the input..... but unfortunately, the linky does not give the "enable" codes !....There is an "autofix enable" panel further down, which I did, but that has not fixed the problem.!...
(It did not say to re-boot the computer,.... UNTIL you "close" the little window which says it is fixed, and you have options to say how good it was etc)
UPDATE....... after a re-boot................... PROBLEM SOLVED...... Thanks guys... the thing that fixed it is on this page.....
about halfway down, there are two "AUTOFIX" boxes..... one to disable the other to enable....
Thanks RR..
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
- « Previous
- Next »
