Anyone got a Growatt hybrid inverter?
ExForce9
Seasoned Pro
Fixes: 6
Re: Anyone got a Growatt hybrid inverter?
@Marksfish wrote:
This AI lark is very clever isn't it?
I'm currently using Grok for free.  It will remember your conversations if you sign-in using your email address, and allow you more questions each day (compared with asking questions when not logged in), but not as many as if you pay for a subscription.
For your inverter/logger debugging process, just explain to it EXACTLY what you have, what you are trying to achieve, and what you are currently struggling with, and it will produce a page of what to try next.
If you don't believe it, or don't understand, just tell it and it will correct itself, and explain more clearly, etc
In your debugging process, keep adding to the conversation, as it will remember the previous context, and produce solutions to your current level of progress.
For example, I just asked it about your 10.10.10.4 IP address, and it came back with this lot -
10.10.0.4 is almost certainly the server address the ShineWiLan-X2 is configured to talk to (the Growatt cloud / MQTT endpoint), not the datalogger’s own local IP address on Mark’s home network.
Where the address comes from
The ShineWiLan-X2 has two completely separate IP-related settings:
  1. Its own local network IP (what Home Assistant needs for Modbus TCP on port 502)
    • Normally obtained automatically via DHCP from the home router.
    • This is the address that should appear in the router’s client list (often with hostname = the stick’s serial number).
  2. The remote server address it reports data to
    • Default is the domain mqtt.growatt.com (or the equivalent regional Growatt server).
    • This can be overridden to a raw IP address in the stick’s advanced configuration.
    • 10.10.0.4 is a private (RFC 1918) address, so it is not reachable from the public internet and is not a valid Growatt cloud server. It was almost certainly set manually at some point (previous installer, test, wrong copy-paste, or a leftover static-server setting).
That is why Mark sees the stick “connecting externally to 10.10.0.4” — the stick is trying to push data to that (wrong) server IP.
What it should be
  • Local IP of the stick (for Home Assistant): whatever the home router assigns (e.g. 192.168.1.xx or 192.168.0.xx). This must be on the same subnet as Home Assistant and reachable on TCP port 502.
  • Server address (for the official Growatt cloud / ShinePhone): the domain mqtt.growatt.com (preferred) or the correct public Growatt server IP for the region. Leave it on the domain unless there is a very specific reason to use a raw IP.
How to change / fix it
Use the ShinePhone app (Bluetooth method is the most reliable):
  1. Put the ShineWiLan-X2 into Bluetooth mode (short-press the button on the stick until the LED is steady blue).
  2. Open ShinePhone → go to the plant → configure / manage the datalogger (or “My” → Configure Datalogger and scan/enter the SN + check code).
  3. Enter Advanced settings (sometimes labelled for professionals / commissioning).
  4. Open the Server configuration page. You will see the current server domain / IP and port.
  5. Change it back to the domain mqtt.growatt.com (or leave the domain field active and clear any hardcoded IP). Port is normally 7006 (or the value the app shows by default).
  6. Save and let the stick reconnect.
You can also view the current server settings on that same page without changing anything.
Alternative / additional checks
  • Factory-reset the stick (long-press the button ~6 seconds until the LED turns white). This restores dynamic (DHCP) local IP and clears most network settings, but does not always wipe the server domain/IP — so you may still need to correct the server setting afterwards.
  • After correcting the server address, confirm in the router that the stick has a sensible local IP on the home LAN, then use that IP in the SolaX Modbus integration (port 502, slave 1).
Once the server address is fixed, the stick should resume normal cloud reporting, and the local Modbus TCP interface (the one Home Assistant uses) will continue to work independently on the stick’s real LAN IP.
If Mark can tell you the exact screen/page where he sees “10.10.0.4”, or whether it appears in ShinePhone under the datalogger details, that will confirm it is the server field.
Marksfish
All Star
Fixes: 5
Thanks for all your help on this, but i'm just going to admit defeat.
The only thing I haven't done is to update the inverter firmware, but trying to get hold of anyone able to provide that is like trying to get ice from the desert! I have come to the conclusion that even though the website states my inverter is supported, I don't think it is. The new datalogger arrived, so I tried it and have the same issue, so it isn't the datalogger. It is either me or the inverter.
Mark
ExForce9
Seasoned Pro
Fixes: 6
@Marksfish wrote:
The only thing I haven't done is to update the inverter firmware, but trying to get hold of anyone able to provide that is ...
Did you try asking Grok ?
If you are stranded by a uncontactable installer and cannot get through to Growatt via standard phone calls or emails, you can bypass them by using alternative direct technical contact channels or registering your own installer account to force a remote update.
Method 1: Contact Direct Support via WhatsApp
Growatt UK service engineers rarely answer the main office line because they primarily interact with field installers via mobile apps. If you contact individual technical support engineers directly on WhatsApp, you will have a much higher success rate:
  • Yujian Chen: WhatsApp at +44 7518477560
  • Yifan Wu: WhatsApp at +44 7384028681
  • Carolina: WhatsApp at +44 7999518379
  • Leo: WhatsApp at +44 7536968906
What to send them: Message them a photo of your inverter's serial number sticker, a screenshot of your current firmware version, and state that your original installer is no longer trading. Ask them to push a remote Over-The-Air (OTA) firmware update to your SPH-3600 via your ShineWiFi/ShineLan stick.
Method 2: Create a Free Growatt Installer Account (OSS Platform)
If you cannot reach anyone, you can register as an installer on Growatt's Online Smart Service (OSS) Platform to trigger the firmware update yourself. Growatt does not strictly verify company details during registration.
  1. Go to the Growatt OSS Portal on a computer desktop browser.
  2. Click Register and choose Installer Account.
  3. Enter your country and your Inverter Serial Number (S/N).
  4. Fill out the form. You can use your own name for the "Company Name" and your home address.
  5. Verify the account via your email address and log in.
  6. Navigate to Device List or Upgrade Manager.
  7. Enter your serial number and click One-Click Upgrade to push the latest firmware remotely.
Method 3: Try Major UK Distributors
If you need physical firmware files (.bin or .hex) to update via a USB stick, contact major UK solar distributors who have direct engineering access to Growatt software repositories:
Marksfish
All Star
Fixes: 5
Thanks for that. I didn't register with Grok, I have tried the Google equivalent for a lot of stuff though. I must confess to being a bit wary of the firmware update, in case it bricks the inverter, I have seen some issues reported online and am wondering if it's the firmware updated that's screwed the dataloggers..
I'm placing it all on the back burner at the moment though, I have had enough of trying to get something that is supposed to be plug and play working, it is just causing me frustration. I find in situations like this, I sometimes need to step back for a while and take a fresh look at it in a couple of weeks.
Thanks again for all your input.
Marksfish
All Star
Fixes: 5
Just to put this to bed, Growatt finally answered me. Despite my due diligence prior to purchase and the research I have found online, the datalogger is not compatible with my inverter. A bit annoyed really as I wouldn't have invested the time and effort into it if I had known. The manufacturer isn't interested in correcting the duff info out there. I was lucky, I was able to sell it on for not much less than I bought it for.
Time for another project...
Mark
