Any iPhone/iPad experts around?
petlew
Re: Any iPhone/iPad experts around?
It seems the reason I'm not aware of it is due that I don't have that setting. This is in the iPad/FaceTime settings. I don't think I have a settings in FaceTime itself unless I'm online with a call, then I think I can change things. Offline all I have is myself on screen with a contacts menu. The only thing I can do there is edit a contact details.
I do have a lengthy "Blocked number" list in the iPad FaceTime settings, but none of my contacts are on it. There is also a list of 3 "busy" responses, but they're all greyed out not being used.
Perhaps this is all due to the rather elderly iPad that doesn't get later updates.
spraxyt
Resting Legend
Fixes: 75
The setting I mentioned is shown in this image
However since my previous post I've checked with a neighbour who routinely uses FaceTime for calls to and from Australia. His settings also show "Never" but calls ring fine in both directions.
The other options for that setting are Headphones and Car. Headphones only and Always. I wonder if "Announce" means spoken "Call from ..." rather than just ringing.
David
petlew
@spraxyt
My iPhone is running the same version of iOS as yours.
My iPad version is 9.3.5 and won't update any further. I'm warned I can't if I check for updates.
However neither "Settings/FaceTime" looks the same as your screen shot. Above your "Call blocking etc." (mine is just called Blocked) I do not have the "Announce Calls" option in either iPhone or Pad. There is nothing at all in either of mine in that position.
I do though have one not in your screenshot. Below FaceTime with the green on/off switch in the iPad I have an option named "Calls from iPhone" also with a green on/off switch. The iPhone lacks this option as well.
I haven't tried switching this off as I don't think its anything to do with my problem.
So neither of mine are exactly the same as yours. Between us we have three different setting views.
