Android audio players
Mav
Fixes: 515
I have tried the built-in Google Play Music and VLC players but neither seem intuitive or comprehensive in their use.
I'm not bothered about playlists just want to be able select all songs stored and randomly play them. Maybe an equaliser but not essential.
Does anyone have any suggestions?
Forum Moderator and Customer
5 REPLIES 5
HairyMcbiker
All Star
Fixes: 21
Re: Android audio players
I tend to use either Mort player or winamp.
Mav
Fixes: 515
Can't believe I didn't think of WinAmp as it's the main player on my PC Cheesy
Trouble is I haven't find it by searching in GooglePlay. There is a link to it from the WinAmp forum but you need to login to FaceBook Sad
shutter
Fixes: 65
Not tried any.... but google came up with this page, when asked for  " Android Audio Players "
http://www.talkandroid.com/guides/beginner/the-5-best-android-music-player-apps-may-2014/ ; Wink
DaveyH
Champion
Fixes: 12
I always used to use Poweramp. Plays just about every file format and it customisable/skinable etc - its not free though if it bothers you
Mav
Fixes: 515
I installed WinAmp and n7Player.
Of the two n7Player seems the better but I'll keep both for now and see how things go.
