Android Tablet won`t connect to internet
shutter
Fixes: 67
I don`t use it much... but am testing somethings out, and the Lenovo Android Tablet, will not connect to the internet, so can`t make updates etc. I can make calls out on the phone side of it though. Here is the SIM Card Management page.
ASDA is the priority SIM, the same applies if ASDA is disconnected and 3UK is made the only  active SIM
When trying to use the browser, a page comes up with
You are not connected with the internet
[Refresh]       [Back]
                      Error status
                    Contact Miss UC
on tapping the Error status, it shows
According to "Network Status"  the WIFI is not enabled.
However..
Any suggestions as to how to solve this problem, please.
In simple terms as I am not an expert !
3 REPLIES 3
Fixes: 585
Re: Android Tablet won`t connect to internet
Wifi maybe on but is it connected  ?
RPMozley
Seasoned Pro
Fixes: 18
If you are trying to use mobile data, check the apn settings are correct.
That's RPM to you!!
shutter
Fixes: 67
@MisterW   Been in the settings again, and it seems that the WIFI password needed to be reset,
All is connected to the internet now.
Thanks Wink
