Android DNS - doesn't use nameserver on LAN?
7up
Fixes: 19
Re: Android DNS - doesn't use nameserver on LAN?
@MJN wrote:
Is this DNS server one you've written yourself? If so you really ought to have made that clear from the outset!
Yes. Both are custom written. Sorry I thought I'd made that clear but reading the op again I can see where the confusion could arise. Most here know I've been working on this for a while hence I didn't think about clarifying that as clearly as I should have.
Anyway iis working now! I had given up but tried a 14 day trial of simple DNS and noticed that android did take notice of DNS replies so armed with that new found knowledge I realised it can be done, I just needed to dig further.
MJN
Fixes: 5
No worries; I only pop in from time to time so don't have my finger on the pulse of who gets up to what!
Writting your own DHCP Server and your own DNS Server, with its own GUI, someone has way to much free time on their hands Wink
7up
Fixes: 19
There aren't many free windows offerings for either server so I figured I might as well come up with my own. At least that way I can add extra functionality that I may need in the future. Plus it was a good exercise in dealing with bits and bytes in their raw format along with data packets etc.
Now I just need to make both programs available for free online and gain a user base to help me towards a better future..
MJN
Fixes: 5
What about BIND? It is practically ubiquitous and with nearly 30 years of history rather well developed!
7up
Fixes: 19
Last time I looked at bind it didn't run on Windows and I'm not overly keen on Linux.
MJN
Fixes: 5
Yeah, Windows too.
7up
Fixes: 19
Last time i looked into bind was 2010. Now that you've mentioned it I may have looked at a windows option but for whatever reason decided it wasn't right for me (to be honest, i really can't remember).
Anyway experience has taught me that I am easily frustrated with pre-existing solutions as I can never quite find the right features that I need - thats why i've also been working on a mail server which will accept mail and transfer it via http to my webmail or any other script that i need it to work with.
Also I doubt bind would work dynamically from a usb drive which is functionality that I need for my WAMP setup. With my own solution I can create a server that is designed to run portably instead of being installed. As long as it works reliably for me i'm happy with it.
