AVG free update problem
- AVG free update problem
- « Previous
- Next »
Re: AVG free update problem
09-03-2009 1:05 PM
Thanks for the lifeline John I was sinking in a ocean of doubt
09-03-2009 8:26 PM
I've been suffering from update problems too over the last day or so. Same thing happened last year sometime IIRC. I'll give it a few days and then go back to Avast I think.
21-03-2009 5:58 AM
I upgraded an XP computer last Sunday to 8.5 (7.5 update said support was stopping on the 17th). Subsequent update ran without a problem. Haven't heard of an update issue since, but will check. (7.5 updates on 98SE/ME machines still working!).
An issue I have with that 8.5 upgrade is that Outlook is installed on that machine, but not used. Outlook Express used instead. AVG has installed itself to check Outlook and I can't find any setting to change it. I don't want to uninstall Outlook as one of them may want to use it in due course.
Anybody able to help on that?
21-03-2009 7:36 AM
I've had a few problems where update wouldn't happen automatically. It seems to have corrected itself in the past week and working normally (fingers crossed).
22-03-2009 11:28 PM
No further problems with updates here.
Did another 8.5 install today. Solution to my query above is to pick Advanced Installation not Standard installation.
- « Previous
- Next »
