A technical experiment
I changed the e-mail address associated to my Plusnet account.
I tried logging on using the e-mail address.
I got this.
The e-mail address is (apparently) linked to more than one account.
Clicking on 'request usernames' (plural) brings up an 'e-mail me' link. Which may not work, given the stored e-mail address of '[email protected]'.
(Sanity checks on domain names may be a requirement when people change their details?)
Obviously this can be construed as non-positive comment. But it is technically correct.
9 REPLIES 9
outcast
Aspiring Champion
Fixes: 19
Re: A technical experiment
Were you able to put the email address back to something sensible ?
or did entering your 'username' lock you out because the associated email address is associated with more than one account ?
It seems unlikely that  [email protected]  would be linked to ANY account let alone more than one !
Fixes: 385
@outcast As '[email protected]' is clearly NOT an email address, I am a little confused by the response -I would have expected something more along the lines 'we can't find this address, please try again'.
Fixes: 581
Why ? its got something prior to an '@' , its got at least one '.' in the domain name. The only possible reason for NOT being an email address is that 'null' is probably not a valid TLD.
If the only checking is syntax, then it will pass!.
Fixes: 385
Fair enough, @MisterW , but where would that 'address' route from/to?
I don't want to get into a long discussion on this flight of fancy from our resident 'expert in all things', but it appears someone is trying to be too clever, and failing  - IMO.
Fixes: 581
@jab1 Sorry if I wasnt clear, to you and I its clearly not a valid email address and it wont route anywhere. However, to a computer system just checking syntax, it could well appear to be valid!
Fixes: 385
Totally get that, @MisterW . I was just a little surprised at the 'Plusnet' response in the original post. 😀
Fixes: 1,495
It'll probably be a dev who created a test account that used null email address to avoid real emails being sent..
"Were you able to put the email address back to something sensible ?
or did entering your 'username' lock you out because the associated email address is associated with more than one account ?"
I took the "you'll need your username or e-mail address to log on" as a statement of fact (i.e. either one is acceptible with no dependency between the two). The account was/is still accessible via the username for the account. And the e-mail address associated with that account is now reverted to something more 'sane'.
I wasn't brave enough to try using the (invalid) e-mail address as a method of authentication for the account.
I don't presume to be what you state. I know little about copper lines (ADSL/VDSL, etc.) and the oddities that appear on them.. I think you trump me on that Smiley
