A small Linux Problem !
shutter
Fixes: 67
I have had to change my SSD`s over, as the main one in my ASUS ROG 17" LAPTOP has started to "play up".
Not a problem generally, As I can ( and have just done so ) removed the ssd from my 11" laptop, with the same Linux Mint 22 installed on it.( and all my other stuff ).
The problem is small font sizes on everything...  Web pages are showing about 20to 30% smaller than usual,  ( yeah I know you can use  CTRL + to increas the size of the web page , but I should not have to ! ) .
It is particularly bad on the drop down menus etc of all the other stuff.
see pics..
Note the small font size in the menu on this pic... ( also the icons are about half the "normal size"
The "internal menu" is also about half the "normal size".
Almost impossible to read..  looks like font size 6 when it should be about 12 or 14 .
Have tried to change the "display"
from auto ...  TO 100% but no change.. and going to 200% blows the whole view far too big to fit the screen !
I know that the install was set up on the small(er) screen laptop.   and I have had this problem before, BUT I cannot find, or remember how to change it...
Any help would be appreciated.
20 REPLIES 20
Fixes: 382
Re: A small Linux Problem !
A quick thought - adjust the resolution?
Fixes: 147
@shutter
Have you looked at the Appearance Preferences?
shutter
Fixes: 67
@Dan_the_Van   yes... they are all set at 14... !
shutter
Fixes: 67
@jab1  Have tried lowering the resolution,..but all that seems to do is to make the screen more "square" in shape.. !.
unless you have a better "resolution" solution size !..
Fixes: 147
@shutter
1360 x 768 should be a wide screen setting
Fixes: 382
My 16" is set at 1368 x 768 (16:9) , and is perfect.
shutter
Fixes: 67
@jab1  & @Dan_the_Van  OK>.. thanks for the suggestion... 1368 x 768 certainly improved the size of the drop down menu`s, but not as much as they used to be !.. looking like they are about 2/3rds the font size that I considered "normal" on the other hard drive.
NOTE... the top line menu is still far too small - doesn`t seem to be any changes there.. icons still small, too ! .
Champnet
Fixes: 21
Opticians ?
shutter
Fixes: 67
@Champnet  You might well need to visit one, if you cannot see how small the font is. Huh
Fixes: 382
@shutter I remember reinstalling a backup on my Linux machine sometime last year, and had similar problem - can't remember what I did to sort it, but I know it took me a while and some guesswork - but I eventually got it back to my 'normal'. Not a great help to you, I know, but it is possible.
@shutter
Have you tried running "Driver Manager", in case the ASUS needs a different display driver from the old laptop?
shutter
Fixes: 67
@jab1   Yeah... we both got the same problem.. ( to start with = small text ) and have the same problem remembering what we did to solve it  )(huh ! Undecided ) hence my posting ( again - probably Huh )
So far, there is some slight improvement...but still not 100% happy with the results... getting a bit fed up playing with it tonight...got all  day tomorrow, to have another go !.
Wink
@shutter
In addition to my previous post, try removing any display driver that was installed for the old laptop.
shutter
Fixes: 67
@Anonymous  Nope !... both machines have been running Linux Mint for at least 5 yrs.. and I have always done several  (more than 10)  "new installs", on the small 11inch laptop, and then transferred the hdd to the Asus ( 17inch ) laptop, usually only having to re-arrange ( spread out ) the desktop icons to fit the larger screen... everything else seemed to work ok.. except on two previous occasions, when this small font business appeared.
