550 - relay not permitted
- Re: 550 - relay not permitted
14-04-2009 10:19 PM
I am trying to reply to an email, but I'm getting delivery failure notifications with this error. I am using a charity domain name hosted by 1and1. I understand some ISPs block relayed mail, although this is the first time I have seen it. If I reply form home it is being relayed through PN, of course. I get the same notification if I reply from work (relayed through their ISP, Eclipse), and, strangely, even if I log on to 1and1 webmail and try to send it from there.
I could send it from my PN address, but it looks better coming from the charity domain. Any way round this?
15-04-2009 12:13 AM
Depending on the software you use for email you should be able to set the return address to the charity which may do but the header would show it comes via plusnet if anyone looked.
15-04-2009 7:15 AM
Also uses the 1and1 relay (with authentication) from our PN line..
15-04-2009 7:53 AM
15-04-2009 10:32 AM
Quote from: Bob Does your domain have an spf record?
It appears not. Is it worth asking our webmaster to look into it?
Quote from: adiewoo Can you post the error message? SWMBO uses the 1and1 webmail to send mail with no issues from both her office and my parents with no issues.
I only have 1 message to hand here at work. Tried to send this relayed through Eclipse.
Quote The following message to <[email protected]> was undeliverable.
The reason for the problem:
5.1.0 - Unknown address error 550-'relay not permitted'
Reporting-MTA: dns; smtpout.karoo.kcom.com
Final-Recipient: rfc822;[email protected]
Action: failed
Status: 5.0.0 (permanent failure)
Remote-MTA: dns; [83.170.64.235]
Diagnostic-Code: smtp; 5.1.0 - Unknown address error 550-'relay not permitted' (delivery attempts: 0)
The others are similar, but have come through different servers i.e. not all from Karoo.
Quote from: Samuria Who has the MX record for the domain do you know?
1and1, who host the domain.
15-04-2009 10:33 PM
Quote This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of
its recipients. The following addresses failed:
<[email protected]>
SMTP error from remote server after RCPT command:
host uk2mxarray3.uk2.net[83.170.64.214]:
550 relay not permitted
--- The header of the original message is following. ---
Received: from pustefix157.kundenserver.de (pustefix157.kundenserver.de [172.23.4.157])
by mrelayeu.kundenserver.de (node=mreu1) with ESMTP (Nemesis)
id 0MKv1o-1Ltjob4BWd-000jvW; Tue, 14 Apr 2009 16:40:46 +0200
Message-Id: <26856265.1976971239720046017.JavaMail.servlet@kundenserver>
To: <[email protected]>
Subject: RE: xxxxxxxxx
Cc: <[email protected]>
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_Part_106205_1826661.1239720045966"
X-Priority: 3
X-Binford: 6100 (more power)
X-Mailer: Webmail
X-Originating-From: 30183427
X-Routing: UK
X-Message-Id: <30183427$1239720045966172.23.4.157835882@pustefix157.kundenserver.de--1016514742>
X-Received: from pustefix157.kundenserver.de by 91.85.64.161 with HTTP id 30183427 for [[email protected]]; Tue, 14 Apr 2009 16:40:45 CEST
Date: Tue, 14 Apr 2009 16:40:45 +0200
X-Provags-ID: V01U2FsdGVkX1+S+YLzHSWGHjdBse9wx0r9NAI4i2RCqL98Sid
Nex+NQ13cxBeEppHvjEIWJwUUKfDO6Bvf7/C+nQ1fXRWzwjAG3
rfaULTiPT0=
Oh, good grief! I tried sending a reply direct from my PN address, and as I was typing have just got another error message
Quote Return-path: <>
Envelope-to: [email protected]
Delivery-date: Wed, 15 Apr 2009 22:14:45 +0100
Received: from [212.159.7.39] (helo=mx.ptn-ipin04.plus.net) by
fhw-inmx06.plus.net with esmtp (PlusNet MXCore v2.00) id 1LuCRR-0005tC-5g
for [email protected]; Wed, 15 Apr 2009 22:14:45 +0100
Authentication-Results: mx.ptn-ipin04.plus.net; dkim=neutral (message not
signed) header.i=none
Received-SPF: None identity=pra; client-ip=84.92.2.97;
receiver=mx.ptn-ipin04.plus.net; envelope-from="";
x-sender="[email protected]";
x-conformance=sidf_compatible
Received-SPF: None identity=mailfrom; client-ip=84.92.2.97;
Received-SPF: None identity=helo; client-ip=84.92.2.97;
X-SBRS: 5.3
X-IronPort-Anti-Spam-Filtered: true
X-IronPort-Anti-Spam-Result:
Aj4DADPr5UlUXAJhmWdsb2JhbACNRwGIUgEBAQEBCAsKBxFDqm8Ih2WKbg4IgTg
X-IronPort-AV: E=McAfee;i="5300,2777,5585"; a="63119632"
X-IronPort-AV: E=Sophos;i="4.40,194,1238972400"; d="scan'208";a="63119632"
Received: from mx.ironport.plus.net (HELO relay.ptn-ipout01.plus.net)
([84.92.2.97]) by mx.ptn-ipin04.plus.net with ESMTP; 15 Apr 2009 22:14:44
+0100
Received: from localhost by relay.ptn-ipout01.plus.net; 15 Apr 2009
22:14:41 +0100
Date: 15 Apr 2009 22:14:41 +0100
To: [email protected]
MIME-Version: 1.0
Content-Type: multipart/report; report-type=delivery-status; boundary="+rSv.4PvvlctUy.U87bo.E+5bBeR"
Message-ID: <[email protected]>
X-PN-Virus-Filtered: by PlusNet MXCore (v5.00)
X-PN-Spam-Filtered: by PlusNet MXCore (v5.00)
Subject: Delivery Status Notification (Failure)
X-Evolution-Source: pop://[email protected]/
--+rSv.4PvvlctUy.U87bo.E+5bBeR
content-type: text/plain; charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
content-type: message/delivery-status
Reporting-MTA: dns; relay.ptn-ipout01.plus.net
Action: failed
Remote-MTA: dns; [83.170.64.212]
content-type: message/rfc822
Received: from ptb-relay03.plus.net ([212.159.14.147]) by
relay.ptn-ipout01.plus.net with ESMTP; 15 Apr 2009 22:14:10 +0100
Received: from [212.159.113.65] (helo=[192.168.1.64]) by
ptb-relay03.plus.net with esmtp (Exim) id 1LuCQs-0002az-Kw; Wed, 15 Apr
2009 22:14:10 +0100
Subject: Re: xxxxxxx
Reply-To: [email protected]
To: xxxx <[email protected]>
Cc: [email protected]
In-Reply-To: <000001c9bcdf$ed3e45e0$c7bad1a0$@com>
References: <000001c9bcdf$ed3e45e0$c7bad1a0$@com>
Content-Type: text/plain
Date: Wed, 15 Apr 2009 22:14:09 +0100
Message-Id: <1239830049.5876.4.camel@denzil-desktop>
Mime-Version: 1.0
X-Mailer: Evolution 2.24.3
Content-Transfer-Encoding: 7bit
X-Plusnet-Relay: a08a3ab3a235175b5ab8e40cb42fd3a0
16-04-2009 3:38 PM
16-04-2009 3:46 PM
16-04-2009 3:53 PM
Quote Resolving host name "mail.xxxxxxxx.me.uk"...
Connecting to host address "xxx.xxx.x.xxxx"...
Connected.
S 220 mail.xxxxxxxxxxxxx.me.uk ESMTP (Code-Crafters Ability Mail Server 2.63)
C HELO find-ip-address.org
S 250 mail.xxxxxxxxx.me.uk
C MAIL FROM: <[email protected]>
S 250 Email address accepted. <[email protected]>
C RCPT TO: <[email protected]>
S 550 Account is not local, relaying disallowed. <[email protected]>
This host states that the address is not valid.
Disconnected.
16-04-2009 8:17 PM
Quote ...
S 550 relay not permitted
Disconnected.
[email protected]
address is not
a valid suitable e-mail box address.
So, if I can get in touch I can suggest what they need to do to start receiving emails!
