2G or not 2G? That is the question.
pvmb
Aspiring Champion
Fixes: 15
Re: 2G or not 2G? That is the question.
@RPMozley
"I can’t get into the dashboard either, even after trying to add a CC. Seems my card issuer is blocking it as “suspected fraud” and I can’t complete the adding payment method." 🤣
"Some tempting prices from Now there although data amount isn’t really much of a factor for us, since most of the time we’re in a dead zone for mobile signal."
No use in my 2G phone either! However, as a second SIM for my Tesco purchased smartphone they are rather tempting...
Meanwhile, on the RWG website, things are stirring! £5 and under plans have resurfaced:
BASIC FLEX - 5GB Data £5
UK TEASER - 750mb(sic) Data £2
UK TEASER LITE - 2GB Data £3.50
Albeit, at present all those plans lead to:
Plan Not Found
"This plan isn't available at the moment. You can explore other available plans or go back to continue."
pvmb
Aspiring Champion
Fixes: 15
...The above deals now highlighted on the RWG website: SIM-Only Mobile Plans and Pricing | RWG Mobile
corringham
Seasoned Champion
Fixes: 23
I took out a £3.50 UK Teaser Lite plan two or three months ago to replace a fixed term plan with lower price & similar specs - works fine for me. There was a week or two where I missed calls, or had poor call quality, but I suspect it was my local mast that had issues - it has been fine recently.
