BT Sport issues
Fixes: 1,662
BT Sport issues
Hey all,
We're aware of a problem where BT Sport via the app or the online web-player may not work for you while on a Plusnet broadband connection, which we're investigating and we'll fix as soon as we can.
In the meantime, try turning your router off and on. If you're still having issues, you may need to leave your router off for a bit longer, up to 65 minutes if at all possible, then switch it back on again.
If you need further help, feel free to post in our TV board Here.
I'll endeavour to update this service status as soon as I've got more information to share.
We're really sorry for the inconvenience.
1 REPLY 1
Fixes: 1,662
Re: BT Sport issues
We believe we've fixed the problem now, so you should be able to use your BT Sport App as normal.
If you're still having issues, create a topic in our TV board Here for help.
