you don't help yourselves plusnet
- Feedback
- Plusnet Feedback
- you don't help yourselves plusnet
27-01-2010 9:23 AM
Oh well - I should have known it was too good to be true. I've only been "up" for two weeks and steadilly over that time the speed has dropped to it's present level of 1.7Mb/s. At this rate, in about a week I'll be back to tiscali's pathertic levels and worse - when's it going to stop slowing down.
THEN - as if to compound it all I get an email this morning from PN regarding my speed. Here's a snippet from it:
Quote Dear Mr ***********
Account username: *************
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 6.5Mbps
Current line speed: Not available
You can keep a track of your line speed through our website:
Can one of you geniuses tell me the point in sending me this?
Re: you don't help yourselves plusnet
27-01-2010 9:41 AM
Firstly, apologies for the email, I've raised a problem internally to get this sorted (60334).
Regarding your connection, the speed profile dropped from 6000 to 2000 on the 24th. What's your setup like? We should certainly be able to squeeze more out of your line.
27-01-2010 10:21 AM
Quote from: Mand Regarding your connection, the speed profile dropped from 6000 to 2000 on the 24th.
what does this mean? and why did it?
Quote from: Mand What's your setup like?
How do you mean? One thing I can say is NOTHING has changed at my end.
Quote from: Mand We should certainly be able to squeeze more out of your line.
Squeeze! - an increase from my current 1.7Mb/s to the 4Mb/s I was getting a few days ago is a tad more than a "sqeeze" I'd have thought. You're not exactly filling me with confidence.
27-01-2010 1:09 PM
Quote from: whistler what does this mean? and why did it?
It means that the exchange has picked up a couple of disconnections on your line, and has lowered the speed of your connection - this is to prevent further connection drops as lines running at a slower connection speed are less susceptible to noise and interference. These are the main causes of connection drops like this.
Quote from: whistler How do you mean? One thing I can say is NOTHING has changed at my end.
Basically how is your router wired to the phone sockets and computers in your house. Is it on an extension cable, and most importantly is it plugged into the master BT socket?
Quote from: whistler Squeeze! - an increase from my current 1.7Mb/s to the 4Mb/s I was getting a few days ago is a tad more than a "sqeeze" I'd have thought. You're not exactly filling me with confidence.
I suspect that was meant in a slightly tongue in cheek manner, though certainly not to cause offence - your line should indeed be capable of a much faster connection than it is running at currently, and we'll be happy to chase that for you.
27-01-2010 1:45 PM
Quote from: Matt [It means that the exchange has picked up a couple of disconnections on your line, and has lowered the speed of your connection - this is to prevent further connection drops as lines running at a slower connection speed are less susceptible to noise and interference. These are the main causes of connection drops like this.
So I've been using the service virtually every day and never had a drop out or a problem and BT decide to improve things by slowing me down by more than 50% - how kind of them - you'd think with all the complaints flying around here concerning BT they'd concentrate on those reporting problems and leave their happy customers alone.
Quote from: Matt Basically how is your router wired to the phone sockets and computers in your house. Is it on an extension cable, and most importantly is it plugged into the master BT socket?
My system (a router and a single wired PC with my wife's laptop on wireless) is wired exactly the same as it has been for 5 years. The router is not on an extension cable - it's on a "hard wired" i.e. inside the walls - socket. No it's not plugged into the master socket - it's in my upstairs office and the master socket is in my downstairs hallway. I really don't want to move my office downstairs into the hallway if I can avoid it. BUT - (BT's) disconnections on my line can't have anything to do with anything my side of the socket - so where are we going with this?
Quote from: Matt I suspect that was meant in a slightly tongue in cheek manner, though certainly not to cause offence - your line should indeed be capable of a much faster connection than it is running at currently, and we'll be happy to chase that for you.
No offence taken - maybe my sense of humour is taking a bit of a kicking these days. Certainly my line is capable of much faster speeds - it was doing just fine at 4Mb/s before BT decided to improve my service down to 1.7Mb/s - but then that takes us round in a circle to point 1 again. Ho hum.
27-01-2010 1:55 PM
If you try rebooting your modem/router you should see the higher speeds again.
27-01-2010 2:21 PM
It's now actually better than before at 5Mb/s. Also just did a check and it's 100% transfer efficiency with 0% (obviously) re-transmited packets.
Interesting however that BT slowed it, but it "corrected itself" - not that I'm complaining. Thanks for getting back.
27-01-2010 2:32 PM
Quote from: whistler My system (a router and a single wired PC with my wife's laptop on wireless) is wired exactly the same as it has been for 5 years. The router is not on an extension cable - it's on a "hard wired" i.e. inside the walls - socket. No it's not plugged into the master socket - it's in my upstairs office and the master socket is in my downstairs hallway. I really don't want to move my office downstairs into the hallway if I can avoid it. BUT - (BT's) disconnections on my line can't have anything to do with anything my side of the socket - so where are we going with this?
Have any changes been made to equipment plugged in to the downstairs phone socket (including temporary changes which mean putting plugs in and out)?
Have you had any recent different electrical equipment not connected to the phone which is near the route of the cable from downstairs to your office?
Some sort of interference caused a disconnection and synchronisation at a lower speed; if it happened once it could happen again.
Regarding your comment about moving your office downstairs, there are several ways in which your router could be situated near the master socket to give absolute optimal broadband performance and the ethernet extended to your office upstairs.
27-01-2010 3:41 PM
Quote from: jelv Have any changes been made to equipment plugged in to the downstairs phone socket (including temporary changes which mean putting plugs in and out)?
No
Quote from: jelv Have you had any recent different electrical equipment not connected to the phone which is near the route of the cable from downstairs to your office?
No
Quote from: jelv Some sort of interference caused a disconnection and synchronisation at a lower speed; if it happened once it could happen again.
Well - my phone is supposed to be transferring from BT to PN tomorrow and the phone line did go dead during a voice call I think last Friday morning for a couple of minutes. I assumed it was a part of the switch over shenanigans. This has NEVER happened before to my knowlege in 20 years at this address.
Quote from: jelv Regarding your comment about moving your office downstairs, there are several ways in which your router could be situated near the master socket to give absolute optimal broadband performance and the ethernet extended to your office upstairs.
I was being a little "tongue in cheek" if needs be I'll do this but I'll need convincing first - not least because earlier Matt said
Quote the exchange has picked up a couple of disconnections on your line
Surely this has nothing to do with what happens on my LAN. For example I could turn my router off or disconnect it entirely and there'd be zilch on the line - BT wouldn't know or care. A "disconnection on the line" has to be an "outside" issue doesn't it?
27-01-2010 4:20 PM
The disconnects seen may well be the work on the exchange, which would explain a lot - mostly why your line has been so rock solid, then a wobble for the work, then back to rock solid again. In that case it's nothing to worry about at all.
With regard to disconnections, when you turn off the router it disconnects from the service - the exchange equipment doesn't distinguish this from, say, a drop caused by a cable break or noise/interference on the line. All it sees is that the service is no longer connected. Any disconnection is recorded as such, no matter what the cause.
27-01-2010 4:44 PM
Quote from: Matt With regard to disconnections, when you turn off the router it disconnects from the service - the exchange equipment doesn't distinguish this from, say, a drop caused by a cable break or noise/interference on the line. All it sees is that the service is no longer connected. Any disconnection is recorded as such, no matter what the cause.
That's why a lot of people leave their routers on 24x7 - it's also why I have mine on a UPS!
27-01-2010 5:15 PM
Quote from: Matt It means that the exchange has picked up a couple of disconnections on your line, and has lowered the speed of your connection - this is to prevent further connection drops as lines running at a slower connection speed are less susceptible to noise and interference. These are the main causes of connection drops like this.
Quote from: Matt The disconnects seen may well be the work on the exchange, which would explain a lot - mostly why your line has been so rock solid, then a wobble for the work, then back to rock solid again. In that case it's nothing to worry about at all.
Taking the above two together - BT do work on the line which causes disruption - then seeing that disruption, they decide to forget they caused it a cut my broadband in half to give me a more reliable service. Have I got that right?
So turning off my kit when I (say) go on holiday results in BT slowing my connection when I come back - cute. Kind of makes a mockery of fire safety - wonder what my house insurance company would say - only kidding - I know exactly what they'd say.
Seriously - are you saying that when I go on holiday and turn my kit off - my speed is likely to be dropped because of it?
27-01-2010 5:17 PM
27-01-2010 5:21 PM
Quote from: whistler Seriously - are you saying that when I go on holiday and turn my kit off - my speed is likely to be dropped because of it?
It's how frequently the disconnects occur that BT look at. I'd recommend only turning the router off if it's going to be a couple of days or more.
27-01-2010 5:23 PM
Quote from: Mand Hi there,
I was under the impression that silly emails was being looked into allready.
