you don't help yourselves plusnet
whistler
When I first got my BB connection with PN I thought - well - there's been problems setting it up but - wow - the 4Mb/s I'm getting over tiscali's p*ss poor 1Mb/s will do me - just fine and dandy.
Oh well - I should have known it was too good to be true. I've only been "up" for two weeks and steadilly over that time the speed has dropped to it's present level of 1.7Mb/s. At this rate, in about a week I'll be back to tiscali's pathertic levels and worse - when's it going to stop slowing down.
THEN - as if to compound it all I get an email this morning from PN regarding my speed. Here's a snippet from it:
Dear Mr ***********
Account username: *************
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 6.5Mbps
Current line speed: Not available
You can keep a track of your line speed through our website:
Can one of you geniuses tell me the point in sending me this?
37 REPLIES 37
Mand
Re: you don't help yourselves plusnet
Firstly, apologies for the email, I've raised a problem internally to get this sorted (60334).
Regarding your connection, the speed profile dropped from 6000 to 2000 on the 24th. What's your setup like? We should certainly be able to squeeze more out of your line.
whistler
Quote from: Mand
what does this mean? and why did it?
Quote from: Mand
How do you mean? One thing I can say is NOTHING has changed at my end.
Quote from: Mand
Squeeze! - an increase from my current 1.7Mb/s to the 4Mb/s I was getting a few days ago is a tad more than a "sqeeze" I'd have thought. You're not exactly filling me with confidence.
orbrey
Quote from: whistler
It means that the exchange has picked up a couple of disconnections on your line, and has lowered the speed of your connection - this is to prevent further connection drops as lines running at a slower connection speed are less susceptible to noise and interference. These are the main causes of connection drops like this.
Basically how is your router wired to the phone sockets and computers in your house. Is it on an extension cable, and most importantly is it plugged into the master BT socket?
I suspect that was meant in a slightly tongue in cheek manner, though certainly not to cause offence - your line should indeed be capable of a much faster connection than it is running at currently, and we'll be happy to chase that for you.
whistler
Quote from: Matt
[It means that the exchange has picked up a couple of disconnections on your line, and has lowered the speed of your connection - this is to prevent further connection drops as lines running at a slower connection speed are less susceptible to noise and interference. These are the main causes of connection drops like this.
So I've been using the service virtually every day and never had a drop out or a problem and BT decide to improve things by slowing me down by more than 50% - how kind of them - you'd think with all the complaints flying around here concerning BT they'd concentrate on those reporting problems and leave their happy customers alone.
Quote from: Matt
My system (a router and a single wired PC with my wife's laptop on wireless) is wired exactly the same as it has been for 5 years. The router is not on an extension cable - it's on a "hard wired" i.e. inside the walls - socket. No it's not plugged into the master socket - it's in my upstairs office and the master socket is in my downstairs hallway. I really don't want to move my office downstairs into the hallway if I can avoid it. BUT - (BT's) disconnections on my line can't have anything to do with anything my side of the socket - so where are we going with this?
Quote from: Matt
No offence taken - maybe my sense of humour is taking a bit of a kicking these days. Certainly my line is capable of much faster speeds - it was doing just fine at 4Mb/s before BT decided to improve my service down to 1.7Mb/s - but then that takes us round in a circle to point 1 again. Ho hum.
Chris
Legend
Fixes: 169
It looks like it's corrected itself, the profile increased back to 6000 late last night and updated on our systems now too.
If you try rebooting your modem/router you should see the higher speeds again.
whistler
well you're the man chris - allways good news when you appear  Wink
It's now actually better than before at 5Mb/s. Also just did a check and it's 100% transfer efficiency with 0% (obviously) re-transmited packets.
Interesting however that BT slowed it, but it "corrected itself" - not that I'm complaining. Thanks for getting back.
jelv
Fixes: 10
Have any changes been made to equipment plugged in to the downstairs phone socket (including temporary changes which mean putting plugs in and out)?
Have you had any recent different electrical equipment not connected to the phone which is near the route of the cable from downstairs to your office?
Some sort of interference caused a disconnection and synchronisation at a lower speed; if it happened once it could happen again.
Regarding your comment about moving your office downstairs, there are several ways in which your router could be situated near the master socket to give absolute optimal broadband performance and the ethernet extended to your office upstairs.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
whistler
Quote from: jelv
No
Quote from: jelv
No
Quote from: jelv
Well - my phone is supposed to be transferring from BT to PN tomorrow and the phone line did go dead during a voice call I think last Friday morning for a couple of minutes. I assumed it was a part of the switch over shenanigans. This has NEVER happened before to my knowlege in 20 years at this address.
Quote from: jelv
I was being a little "tongue in cheek" if needs be I'll do this but I'll need convincing first - not least because earlier Matt said
Surely this has nothing to do with what happens on my LAN. For example I could turn my router off or disconnect it entirely and there'd be zilch on the line - BT wouldn't know or care. A "disconnection on the line" has to be an "outside" issue doesn't it?
orbrey
Hi Whistler,
The disconnects seen may well be the work on the exchange, which would explain a lot - mostly why your line has been so rock solid, then a wobble for the work, then back to rock solid again. In that case it's nothing to worry about at all.
With regard to disconnections, when you turn off the router it disconnects from the service - the exchange equipment doesn't distinguish this from, say, a drop caused by a cable break or noise/interference on the line. All it sees is that the service is no longer connected. Any disconnection is recorded as such, no matter what the cause.
jelv
Fixes: 10
Quote from: Matt
That's why a lot of people leave their routers on 24x7 - it's also why I have mine on a UPS!
whistler
OK - Thanks Matt, but lets just take this one step at a time so I understand it correctly...
Quote from: Matt
Quote from: Matt
Taking the above two together - BT do work on the line which causes disruption - then seeing that disruption, they decide to forget they caused it a cut my broadband in half to give me a more reliable service. Have I got that right?
Quote from: Matt
So turning off my kit when I (say) go on holiday results in BT slowing my connection when I come back - cute. Kind of makes a mockery of fire safety - wonder what my house insurance company would say - only kidding - I know exactly what they'd say.
Seriously - are you saying that when I go on holiday and turn my kit off - my speed is likely to be dropped because of it?
Chris
Legend
Fixes: 169
Not every reconnection will cause your speed to reduce, if you want some light (not so light really) reading on how it works and speed faults take a look here: link:speed
jelv
Fixes: 10
It's how frequently the disconnects occur that BT look at. I'd recommend only turning the router off if it's going to be a couple of days or more.
Bud
Quote from: Mand
I was under the impression that silly emails was being looked into allready.
