webmail
- Feedback
- Plusnet Feedback
- webmail
webmail
17-03-2014 2:11 PM
Am the only one having this problem ?
Re: webmail
17-03-2014 4:26 PM
I'm really sorry for the problems you're experiencing with the slow access to Webmail. We've got a Service Status here http://www.plus.net/supportpages.html?a=2&support_action=maintenance&ispservice_id=email which gives a date for when work is due to be carried out on this.
I'm sorry for the problems that this has causing you.
Re: webmail
17-03-2014 4:35 PM
I hope the work cures the problem.
Re: webmail
18-03-2014 11:05 AM
Sorry, but does not make any difference what the service status is. On my Pc The speed always rubbish., I run windows 7 its rubbish, I run apple OX its rubbish.
But if i use my ipad or my iPhone its ok no problems.
Please explain that.
regards landranger
Re: webmail
18-03-2014 11:44 AM
And when you say fine with iphone/ipad, are you using safari to access webmail or just have the emails setup as profiles in Mail?
Re: webmail
18-03-2014 11:45 AM
You've not mentioned in your previous post that you're having problems with the speed of your connection, I will have a look at your line now though.
The problem is likely when using Webmail directly, which is where the problem lays. Using IMAP/POP like your iPhone does will work fine.
Re: webmail
18-03-2014 11:50 AM
There's no extra charge for this. The changeover should take effect overnight.
Re: webmail
18-03-2014 4:06 PM
Well thanks for moving me over, But the reason i use webmail is because i move from site to site. i connect in many differnt locations, AND AS FOR AS LONG AS I CAN REMEMBER THE WEBMAIL AS BEEN EXCRUCIATINGLY SLOW.
INFACT So slow i joined AOL. how bad is that. With AOL it does not matter where i am IT IS STILL FASTER THAN PLUSNET.
WHAT IS REALLY MAKES WANT TO PUT MY FIST THROUGH THE LAPTOP IS THE WAY IT JUST DOES NOTHING WHEN YOU WANT TO RETURN TO THE INBOX TO READ ANOTHER MESSAGE.
In fact i have to close the browser ( usually chrome) and try and log in again, but this does not always work.
Help
Re: webmail
18-03-2014 4:09 PM
I'm sorry that it's causing you issues, you can, in the meantime set up e-mail via Outlook or Thunderbird for example using SMTP Authentication as shown here: http://www.plus.net/support/email/setup/ which should allow you to use e-mail at various different locations.
Re: webmail
18-03-2014 4:32 PM
Re: webmail
18-03-2014 4:37 PM
I'm sorry that you feel the need to move ISP's. Have you tried using a Mail Client as per the above link?
Re: webmail
18-03-2014 4:43 PM
Re: webmail
18-03-2014 4:47 PM
