very poor service and a warning re 21cn "upgrade"
- Feedback
- Plusnet Feedback
- very poor service and a warning re 21cn "upgrade"
- « Previous
- Next »
Re: very poor service and a warning re 21cn "upgrade"
28-05-2012 3:13 PM
Quote from: Joanne Hi toutlemonde,
I could put you on ADSL1 on 21CN which works pretty similar to 20CN
Jojo
As I previously posted, Jojo made this change to my connection and it has remained stable.
Dan.
28-05-2012 3:36 PM
Dan, your line is no where near as long, your local conditions will be completely different, as well as any differences resulting from modem/router & MSAN interaction.
toutlemonde, if your connection hasn't dropped because of the lightning, depending on how close, I'd be inclined to do a Disconnect and them power down the modem/router to avoid a possible low sync event/raise in Target SNRM/banded speed. Connect up again when it's well passed. Good luck.
Edit: Forgot to answer your question, yes the computer has to be on. I also keep forgetting to ask, are all your filters similar to this "rat's-tail" type?
28-05-2012 6:21 PM
i only have one filter on the telephone line at the extn box and yes its a rats tail.
i presume any change now to ADSL1 by my forcing the router will interfere with the fixed 800kbps line rate that BT have set?
forgot to ask, whats the difference between ADSL2 and ADSL2+ ?
sorry mr moderator, never considered that a rude word, just slang for drunk!
PMN- had a closer look at 21CN problems generally. only wish i had done this much earlier, there are hundreds of thousands of them. not that it helps but its nice to know i am not one of a small minority. cannot believe this has not had more mainstream media coverage. it really should be renamed 19cn - will certainly not be holding on to my bt shares for too long - it must hit the fan sometime.
28-05-2012 7:09 PM
What makes you think your sync speed is fixed to 800kbps, you aren't banded or if you were, you aren't on the upper limit?
ADSL2=upto 12M; ADSL2+=upto 24M on paper.
Give it a try and see what happens, do it soon though, before dusk approaches.
30-05-2012 1:55 PM
believe line is fixed at 700kbps not 800 as i stated - think its due to SNR fixed at 6dbs.
sorry to play it safe but: slow broadband is bad, no broadband is a disaster for me as i work from home!
will keep you posted
31-05-2012 9:09 AM
I've just checked and can confirm that the order is complete, though from checking your profiles on BTs side I'd guess it's just setting itself up and training. This shouldn't take anything like 10 days but we're not seeing any detail on the line apart from the profile, which is currently showing at 705kb/s - we should have more detail tomorrow (hopefully).
It looks like interleaving has been on since the end of April, not sure why the errors have increased recently though unless it's part of the training period previously mentioned.
I hope things settle for you and the speed improves.
31-05-2012 12:24 PM
so another 24hr watch!
31-05-2012 12:41 PM
31-05-2012 6:42 PM
snr is remaining at 6dbs +/- 1db
attainable rate has increased from 1150kbps on adsl2+ to 1376kbps on adsl1
agreed with plusnet to remain on adsl1 for a further 24hrs to see if any further improvement.
01-06-2012 4:36 PM
- « Previous
- Next »
- Feedback
- Plusnet Feedback
