thanks
tony4384
thanks
Thanks to the call centre, BT Openreach finally nailed the lousy phone line to a fault 40 metres from the box and used a spare good pair on the cable, I've now got a crackle free line and the Broadband is a good 28-30Mb, shame it took them three tries to find the fault but it was an underground fault not at the box or the pole.
I look forwards to the day they take the Fibre to the distribution pole we will then actually get super fast broadband that no ISP can provide until BT gets its antiquated structures ripped up and replaced.
Tony
1 REPLY 1
MatthewWheeler
Fixes: 503
Re: thanks
Glad to hear we got you sorted in the end.
If there's anything else we can help with let us know.
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
