safeguard
MattyC
Fixes: 46
Re: safeguard
It's also the same with new customers. It's an option upon signup, but you specifically have to opt in to have it enabled. Phone signups would require new customers to do it over the member centre.
Strat
Fixes: 565
Re: safeguard
Oops...
Running Waterfox 36.0.1 and viewing the Safeguard page https://portal.plus.net/my-account/safeguard/inactive
The first attached image shows the top right corner ok.
Then Live Chat pops up and the result is the second attached image.
St3
Aspiring Champion
Fixes: 5
Re: safeguard
Ive enabled some of mine and some not Smiley Ill see how it goes if im not able to access sites which i feel dont need to be blocked then ill just disbale the whole thing.
MattyC
Fixes: 46
Re: safeguard
@St3
Are you ok to PM me any feedback you have?
St3
Aspiring Champion
Fixes: 5
Re: safeguard
yes sure Smiley
Anotherone
Champion
Fixes: 21
Re: safeguard
Good idea Plusnet. BUT I do have one major criticism though - that's the statement about "restart your router". It really is about time Plusnet stopped using this advice in the blanket way that they have done so in the past. Restarting a "router" when in most cases it means "modem/router" is damned poor advise for many on ADSL connections especially on 20CN where the resultant resync can mean an adverse change in profile if done at the "wrong" time, especially if they have a dropping connection issue or high errors.
With virtually all these types of product all that's required is a drop and reconnect of PPP session, and it's about time Plusnet's advice clearly stated that, and how to do it. It needs to be a simple small straight forward explanation with a link to a further item about what to do and when, if their particular modem/router doesn't have the ability to Disconnect/Connect the PPP Internet session.
plusnettony
Fixes: 64
Re: safeguard
@AnotherOne We understand what you are saying, and as usual I'll pass the comments on.
 Tony T
Strat
Fixes: 565
Re: safeguard
All I see is this  Cry
Fixes: 380
Re: safeguard
Same here, Strat. But as I'll never be enabliing it, I don't care  Cheesy
Anotherone
Champion
Fixes: 21
Re: safeguard
Thanks Tony.
Strat, I don't know if your post was relating to my remarks, but for clarity, see the attached from https://portal.plus.net/my-account/safeguard/
The same thing is also mentioned in the Help/FAQ para.9
Quote from: http
(NB: You will need to reboot your router after you've clicked this button...............
hillyfields123
Re: safeguard
Makes a change from the opt-out filters that the larger ISPs have now put in place due to government pressure.
spraxyt
Resting Legend
Fixes: 75
Re: safeguard
Quote from: Strat
I get that "setting up broadband" message too. I'm also a Force9 customer and I suspect this "feature" might be specific to those who are not Plusnet (vISP) customers.
David
David
RPMozley
Seasoned Pro
Fixes: 16
Re: safeguard
I get the same with Free-Online, not that I'm going to be using it though (got OpenDNS to do it).
That's RPM to you!!
Strat
Fixes: 565
Re: safeguard
Quote from: Anotherone
Strat, I don't know if your post was relating to my remarks...
Not specifically Chris.
I don't yet have the page in your screen shot available so no on/off switch to operate....if I chose to use this facility.
I guess it's not been set up on my account yet Cool
rongtw
Fixes: 12
Re: safeguard
as far as i see this is just the Thin end of the wedge ,,,,,, it will not be long before we have to accept this as AUTO ON !!!!!!
