rDNS changed back to default
Re: rDNS changed back to default
Mine has reverted too. Support ticket hasn't even been acknowledged yet!
Anyway, normal service resumed...
KevinG
Same here, all fixed now.
Oldjim
Resting Legend
Fixes: 63
mine is fixed as well
ScottStorey
Just for awareness, problem 84655 was raised for this yesterday evening.
I would get more info but I've left my VPN fob in the office. I'm sure someone on CRT will give more of an update tomorrow on what happened.
daaahhnuh
Noticed this had happened to mine as well. I was a little bit miffed as my plusnet username is my actual name!
However, they have only done half a job. Yes the PTR record has been put back for rDNS to <ip>.plus.com. However, there is no corresponding A record for forward lookups. They have left the A record of my Plusnet username tho. Sort it out Plusnet and stop fiddling!
jelv
Fixes: 10
Why would you need a corresponding A record?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
daaahhnuh
Because it had one before all this under <IP>.plus.com. Also, the Internet filter at work blocks IP based URLs.
jelv
Fixes: 10
So what's the issue with using a dynamic DNS service to point to you? That has the advantage of working whether you are on fixed or dynamic IP.
Fixes: 1,495
or get a domain for a few quid a year.
chenks76
All Star
Fixes: 12
Quote from: Oldjim
I just did the same here http://mxtoolbox.com/ReverseLookup.aspx and mine has changed back as well
Reported by ns2.force9.net on 2/7/2015 at 10:08:33 AM
ive just checked mine on that website and it has come back as mail.agcomputers.uk.com ????
where or what has that came from !!!
bobpullen
Fixes: 330
Not sure, but that domain doesn't even exist any more. Quite possibly a custom rDNS entry belonging to a customer who was assigned the IP before you. Do you know what your rDNS was set to a few days ago, or is this the first time you've checked to see what it is?
jelv
Fixes: 10
Interesting:
C:\Users\John>tracert mail.agcomputers.uk.com
Tracing route to mail.agcomputers.uk.com [205.164.14.88]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  tg582 [192.168.1.254]
  2    22 ms    22 ms    21 ms  lo0-central10.pcl-ag05.plus.net [195.166.128.186]
  3    21 ms    21 ms    21 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.176]
  4    31 ms    23 ms    20 ms  xe-1-2-0.pcl-cr01.plus.net [212.159.0.208]
  5    21 ms    20 ms    21 ms  ae2.pcl-cr02.plus.net [195.166.129.7]
  6    21 ms    21 ms    21 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  7    20 ms    21 ms    23 ms  10gigabitethernet5-1.core1.lon1.he.net [5.57.80.128]
  8    24 ms    24 ms    23 ms  10ge5-2.core1.lon2.he.net [72.52.92.222]
  9    87 ms  107 ms    87 ms  100ge1-1.core1.nyc4.he.net [72.52.92.166]
10  156 ms  170 ms  156 ms  10ge9-6.core1.sjc2.he.net [184.105.213.173]
11  155 ms  162 ms  155 ms  10ge1-4.core1.sjc1.he.net [72.52.92.117]
12  158 ms  157 ms  169 ms  energy-group-networks-llc.10gigabitethernet1-3.core1.sjc1.he.net [64.71.150.22]
13  157 ms  157 ms  157 ms  205.164.14.88
Trace complete.
bobpullen
Fixes: 330
I've a sneaking suspicion that will cease to happen once chenks76's rDNS has been corrected.
chenks76
All Star
Fixes: 12
Quote from: Bob
this is the first time i've checked it.
bobpullen
Fixes: 330
Suspected as much.
I've corrected it, so things should look a little less unusual when the changes take effect. I'm not sure when that will be though, because I think the script that updates customers' rDNS is currently disabled whilst our engineers try to establish what happened over the weekend.
