plusnet extra 60gb not enough
matt_2k34
Re: plusnet extra 60gb not enough
who told you it was "better"
and afaik, adsl2 (up to 20mb) can be used with an unlimited package... (i know cause ive got one..)
adamwalker
Fixes: 223
Its worth bearing in mind that some of you who may have an unlimited package could be on a legacy package that you've had for a number of years or there is a possibility that you could have been offered this as part of a retention offer in the past.
Unlimited isn't that feasible now unfortunately unless traffic management was carried out to a more severe degree which I doubt people would want to see happen. I would personally believe that anyone using more than 100gb would be in the minority here and that maybe an extra 10 or 20gb  or the option to add these on to an existing package would be more favourable. I'll stop there before this thread gets merged with the one about pro: http://community.plus.net/forum/index.php/topic,90199.48.html
 Adam Walker
boabness
Quote from: boabness
because extra was meant to be better,  with better up and down speeds but its not  .  its just the same with more caps from plusnet
i did say this on another post on hear, that was my point in all this.
[Moderator's note by Jim (Oldjim):  Full quote of preceding post removed, as per Forum Rules ]
oldjim just what did you edit out ?
nothing eh  just what is your game hear ?
or are you saying we cant quote anyone lol why have we got a quote thing up there if we cant use it ?
so how do the person know i was replying to them now,  if you have removed my quote ,
Oldjim
Resting Legend
Fixes: 63
Read the note and also the Forum Rule
Use of Quotes
Quotes can be a very useful way of making your reply to a post clearer by indicating which post or part of a post you are referring to.
However using them incorrectly can be annoying and make threads very hard to read.
The following rule applies to the use of quotes.
Only quote the full content of a post if :-
a) it is NOT the post immediately before your reply
b) You find that your reply has been forced onto a new page (then edit in the full quote if it's needed.)
In all cases you should think before quoting and wherever possible only use a part of the post you are replying to in order to make it clear which bit of a post your reply refers to.
The Moderators will remove unnecessary full quotes where they are posted immediately after the post being replied to.
boabness
sorry see now what i did,  i was replaying to 4 or five posts and never noticed
