multiple migration order failures, despite valid MAC code
- Feedback
- Plusnet Feedback
- Re: multiple migration order failures, despite val...
11-09-2009 5:15 PM
I'm posting this on behalf of someone to whom I recommended PlusNet.
He is having a nightmare migration experience and is considering giving up on the attempt to move to PlusNet
because they have repeatedly failed to act effectively in ascertaining why his migration date keeps getting put forward
as order after order that PlusNet place with BT Wholesale fails with no adequate explanation of
- WHY it has failed, and , more importantly,
- what PlusNet have done to make sure the next order doesn't also fail in the same manner.
I should add that this is WITH a valid MAC code that is repeatedly accepted by BT Wholesale
and an order number provided.
He is now at the position where, if this third attempt fails, he will consider another ISP as he thinks that
PlusNet aren't being smart enough about sorting out this obviously unacceptable situation.
I, as a referrer, can't really disagree with him.
What exactly are the reasons for a migration order failing once a valid, in-date MAC code has been provided ?
Re: multiple migration order failures, despite valid MAC code
11-09-2009 5:44 PM
12-09-2009 6:42 PM
MAC code expires 21 Sep 09
latest migration date given is 19 Sep 09
one attempt remaining, therefore.
13-09-2009 8:59 AM
Jim
14-09-2009 8:25 AM
14-09-2009 8:46 AM
Your migration is due to complete by the end of September 18th.
Regarding the previous orders, the information that I have is that they were cancelled due to duplicate orders being present on the line. That could be anything from an service level change, to an interleaving order, to a change in product. I'm afraid that because at the time you were not a customer of ours, we are unable to find out that information and BT will also not give it to us.
It's possible that BT Retail / Yahoo would be able to tell you, but I'm afraid that there's not a massive amount that we would have been able to do. Let me know if there are further problems and I can try getting some sense out of Wholesale for you.
15-09-2009 11:26 PM
Quote from: Jameseh @disfroot
The broadband account in question has been unmodified as a BT Total Option 1 'Up to 8M' product for several years. There has not been a request on the customer's behalf for a change in any aspect of his broadband service apart from wanting rid of it; he wouldn't even know what an 'interleaving order' is.
So what a 'duplicate order' actually is, remains an annoying, unexplained mystery.
Can you think of any other things that typically prevent customers of BT Retail migrating to PlusNet on the first attempt ?
I had no idea that a valid MAC code was no guarantee of the ability to migrate a broadband service.
So, to the lexicon of frustration that includes 'tags on the line' that prevent you getting a MAC code, we now have to add 'orders on the line' that prevent the migration even after you've got the code.
This MAC system is broken, isn't it ?
16-09-2009 12:36 AM
16-09-2009 10:55 AM
I don't believe it to be a specific problem to BT Retail customers, but merely to your line sadly
Let me know if you have any further problems and I'll be more than happy to pick it up with Wholesale myself.
16-09-2009 7:24 PM
@Jameseh
Quote The MAC system isn't broken - migration orders rarely fail.
Any numbers for that ? Is it '3 nines', '4 nines', '5 nines' or '5 sixes' ?
Quote I don't believe it to be a specific problem to BT Retail customers, but merely to your line sadly
Does PlusNet issue MAC codes to departing customers when there are PlusNet 'orders on the line', then ?
There must be an Ofcom-approved way of doing these things to avoid the big stick, surely ?
Quote Let me know if you have any further problems and I'll be more than happy to pick it up with Wholesale myself.
If the third migration attempt fails on the 19th, I'll take you up on that offer, thanks.
19-09-2009 3:58 PM
The third migration attempt appears to have failed.
It is now 15h45 on the 19th and your last ticket reply said the latest completion of the order was 'up to midnight' on the 18th.
The MAC code expires on the 21st - the earliest date you give in your automated script for examining the problem again.
This will be too late.
Can you please allocate someone who is actually able to deal with this ?
A brief recap.
After the first failed migration order, on Tues 8 Sep you said
Quote The previous open order has been closed and your broadband order is progressing fine and is due to complete on: 09/09/09
The order failed. On the 11th Sept you said
Quote I have called BT they have advised me that the line is now clear.
The third order has passed the deadline and appears to have failed.
What is the worth of anything that you are told by BT Wholesale at this point ?
21-09-2009 4:31 PM
I'm on the phone to Wholesale currently. They have me on hold whilst they talk to Openreach.
21-09-2009 5:09 PM
Openreach claim there is currently no conflicting order present on the line and this order should complete.
21-09-2009 8:24 PM
Quote from: Jameseh I've just given your referral a ring.
Yes, he rang me to tell me you had called. Thanks for your effort.
Quote from: Jameseh Openreach claim there is currently no conflicting order present on the line and this order should complete.
Same as they said the previous two times, then. So why are they repeatedly not doing the job and aborting the
orders ? Who is actually abandoning the job ? Is it a line technician in an Openreach depot in the service
area of the local DSLAM, a clerk in a regional office or a national centre ?
What is physically involved in migrating a line, btw ?
Is it a purely electronic configuration change that can be performed remotely from a NOC, or does it involve a
physical inspection at the local DSLAM ?
22-09-2009 9:43 AM
I'm not personally aware of whether or not Openreach were consulted when the previous orders failed. All I know is that when I called them, they stated that there were no conflicting orders and the migration should work fine.
With a broadband migration, I don't think there's actually a massive amount of work done - my understanding is that it's just a configuration change as nothing physical is required and it's more of a case of just making changes to the BT RAS to allow the connection to a different ISP instead.
I appreciate that that doesn't offer any logical explanation as to why an order should fail if there is another one present!
- Feedback
- Plusnet Feedback
