latest service status..
Fixes: 1,495
there's a slight mistake..
Service: Portal
Posted: Wed, Feb 25 2015 at 10:49:57
Subject: Workplace Portal Maintenance
Workplace Portal Maintenance - Wednesday 4th March from 00:30 to 7am
When's this work happening?
From 00:30 on Thursday 4th March until 7am.
What does it affect?
Workplace and the Broadband Fault Checker.
How long will it take?
Approximately seven hours.
What does the work involve?
Some essential maintenance is being carried which will result in holding pages on Workplace for around half an hour near to 2am but will have the Broadband Fault Checker down throughout.
Am I likely to notice the work?
You won't be able to access our Broadband Fault Checker for the duration of the maintenance window and holding pages will be in place.
Is there anything else I need to know?
Our support staff will have no access to the Broadband Fault Checker during this period.
Due to the nature of the work we will be unable to progress some faults.
Kind regards,
1 REPLY 1
plusnettony
Fixes: 73
Re: latest service status..
Thanks, I've pointed it out. The work is confirmed as being on <b>Wednesday</b> the 4th.
 Tony T
