diabolical upload speed
- Feedback
- Plusnet Feedback
- Re: diabolical upload speed
25-03-2014 6:32 PM
I have now resorted to going back to adsl as I am paying for a service that I am not receiving and I will be leaving Plusnet at the first opportunity.
Just thought to add # 82616943
25-03-2014 6:35 PM
25-03-2014 7:12 PM
25-03-2014 7:52 PM
25-03-2014 7:55 PM
25-03-2014 9:45 PM
Do you know how far you are from the cabinet?
25-03-2014 10:11 PM
I am 2 miles from the exchange and approximately half a mile from the cabinet.
BTW test results are as follows .... Upload speed achieved during the test was - 0.72Mbps
Additional Information:
Upstream Rate IP profile on your line is - 10 Mbps
Download speedachieved during the test was - 12.38 Mbps
For your connection, the acceptable range of speedsis 9.29 Mbps-13.27 Mbps .
IP Profile for your line is - 13.27 Mbps
26-03-2014 7:56 AM
26-03-2014 10:02 AM
Quote approximately half a mile from the cabinet.
I think this explains why you're seeing such low upload speeds. From looking at the location of your premises and the location of the cabinet, I've got the distance between the two at 1.6 Miles which is 2.5km.
Given this distance in accordance with http://www.increasebroadbandspeed.co.uk/2013/chart-bt-fttc-vdsl2-speed-against-distance your speeds are probably about right, if not a little better than what we would expect.
26-03-2014 1:41 PM
26-03-2014 1:49 PM
This means that for a similar copper line length you would see a much greater percentage speed drop on fibre
In most cases the cab to user distance is much less that the exchange to user distance but it appears from what has been posted your cab is about the same distance from you as is the exchange.
HOWEVER
The distance quoted by you of 0.5 miles and by Chris of 1,6 miles indicates that either you are on a different cab to the one you think you are or something is really screwed.
26-03-2014 1:54 PM
So you are saying that it is pointless installing fibre as basically it is slower than copper.
Another point, if fibre is so much slower how come my download speed is double what it is on copper?
26-03-2014 1:57 PM
This means that the signal used for FTTC degrades over shorter distances quicker, as shown on the graph from the above link.
ADSL uses lower frequencies which can mean that in some instances, you're better off staying on ADSL as opposed to moving to FTTC.
If you can PM me where you believe your Cabinet is, such as a street name, I'll try and confirm to you what the actual cabling distance is, bearing in mind that distance on foot is completely different to how FTTC might be routed.
26-03-2014 2:04 PM
26-03-2014 5:28 PM
Where you live—The distance from your home to the local telephone exchange is the most common factor which affects DSL broadband services as the signal degrades the longer it needs to travel. If you have a fibre-optic broadband connection, you're less affected as the distances are shorter (from your home to the street cabinet instead of the exchange; see the fibre broadband guide for more details)
How near you live to your local exchange will affect the speed of your broadband. If you have fibre broadband, your speed shouldn't be as affected by line length.
