bye bye plus.net
W1ngD1ngs
Re: bye bye plus.net
@Jelv - even 100 with a stable connection is more than I had over Xmas & New Year.  I have a teenager with CoD / Halo / Left for Dead withdrawel symptoms!  Sad
And trying to update / configure his new computer has been fun, Not!  Undecided
@Matt - Thanks for all your efforts, pity the BT "Engineers" aren't as diligent or even trained properly!  Crazy  Will let you know how the connection is performing when I get home tonight!  Cheesy
orbrey
It's still looking very good - an ongoing 10 hour connection with a 1000 profile and a sync speed of 1248. We've asked the team to keep the fault open until we're sure it's resolved though. Let's see how things are tomorrow, but I'm optimistic.
W1ngD1ngs
Post BT REIN "Engineer" visit 28 Jan 2010 @ 18:05
DSL Connection
Link Information
Uptime: 0 days, 9:18:09
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,248
Output Power (Up/Down) [dBm]: 12.0 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 17.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 17 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 38 / 2,587
HEC Errors (Up/Down): 16 / 1,448
Download speed achieved during the test was - 651 Kbps  Kiss
Acceptable range of speeds is 200-1000 Kbps.
DSL Connection Rate :1248 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
PN IP Profile 1000Kbps
My Broadband Speed Checker Date Download Speed Upload Speed
  28 Jan 10 18:09 693 kbps (86.6kB/s) 316 kbps (39.5kB/s)
Braodband Speed Checker  Download 680Kbps Upload  332Kbps
Speedtest.net Download 0.69Mbps Upload  0.35Mbps Ping 57ms
W1ngD1ngs
@ Matt, re-synced this morning:
Post BT REIN "Engineer" visit 29 Jan 2010 @ 07:31 (after re-sync)
DSL Connection
Link Information
Uptime: 0 days, 0:01:31
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,184
SN Margin (Up/Down) [dB]: 16.0 / 7.5
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 2
Download speed achieved during the test was - 857 Kbps
DSL Connection Rate :1184 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
29 Jan 10 07:37 925 kbps (116kB/s) 356 kbps (44.5kB/s)
Broadband Speed Checker  Download 912Kbps Upload  332Kbps
Speedtest.net Download 0.93Mbps Upload  0.35Mbps Ping 57ms
Still worried about the errors ramping up at quite a rate and will monitor.  Thanks for your assistance in returning to a usable BB service. Wink
orbrey
Hi DawnRider,
I've just tested the line and in the 2 hours it's been up there have been 40 errored seconds which isn't too bad - especially given that interleaving is currently turned off. If you're worried then I can put that on, which should pretty much get rid of those - just let me know.
I'm certainly glad that things are now sorted for you, I'll investigate that refund now.
Cheers,
Matt
W1ngD1ngs
Thanks Matt, reference the interleaving:
By how much will it affect 'ping' times? or won't we know till we try it? Undecided
If it is turned on and games start to experience lag, can it easily be turned off again? (I have a teenager who will not be impressed if his multiplayer games are greatly affected!) Sad
orbrey
At a rough guess, you're looking at about an extra 16ms per ping - Bob regularly sees pings of ~35ms with an interleaved line so it shouldn't be that bad, and it's a 24 hour order so easy enough to turn off if you need.
Having said that if the errors aren't too bad at the moment why not leave it off until you think it's needed?
W1ngD1ngs
@Matt, I think that's probably best for the moment.  With no drops and no noticeable lag on Xbox Live the boy's happy! Thanks again Matt.  Cool
orbrey
That's fantastic, thanks very much. Please give us a shout if there's anything else we can help with, or if you decide you do want to enable interleaving and we'll do what we can.
W1ngD1ngs
Hi Matt, everything seems to be holding steady now. I think we can definately leave out the interleaving at the moment to keep the ping times as they are thanks. Stats since last re-sync:
DSL Connection
Link Information
Speedtest.net Ping 57ms Download 0.93Mbps Upload 0.35Mbps
29 Jan 2010 @ 17:20
DSL Connection
Link Information
Uptime: 0 days, 9:28:08
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,216
SN Margin (Up/Down) [dB]: 17.0 / 7.5
Error Seconds (Local/Remote): 21 / 0
CRC Errors (Up/Down): 2 / 1,657
HEC Errors (Up/Down): 0 / 707
Download speed achieved during the test was - 862 Kbps
DSL Connection Rate :1216 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
29 Jan 10 17:24 919 kbps (115kB/s) 330 kbps (41.3kB/s)
Broadband Speed Checker Download 912Kbps Upload 342Kbps
Speedtest.net Ping 57ms Download 0.91Mbps Upload 0.36Mbps
29 Jan 2010 @ 22:07
DSL Connection
Link Information
Uptime: 0 days, 14:11:58
Error Seconds (Local/Remote): 22 / 0
CRC Errors (Up/Down): 16 / 2,879
HEC Errors (Up/Down): 2 / 1,283
Download speed achieved during the test was - 869 Kbps
29 Jan 10 22:14 925 kbps (116kB/s) 368 kbps (46kB/s)
30 Jan 2010 @ 09:38
DSL Connection
Link Information
Uptime: 1 day, 1:43:25
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,216  Smiley
Error Seconds (Local/Remote): 39 / 0  Undecided
CRC Errors (Up/Down): 17 / 4,703  Undecided
HEC Errors (Up/Down): 3 / 2,173  Undecided
Download speed achieved during the test was - 871 Kbps Smiley
30 Jan 10 09:40 923 kbps (115kB/s) 322 kbps (40.3kB/s)  Smiley
Broadband Speed Checker Download 920Kbps Upload 312Kbps
  Smiley
Speedtest.net Ping 57ms Download 0.92Mbps Upload 0.29Mbps  Smiley
Thanks again for your perseverance and forbearance during this rather drawn out affair.
Pete Allison
orbrey
Hi Pete,
I'm glad everything's holding up well - I don't think those errors are too bad though if they do start to affect the connection let us know and we'll get some testing done.
W1ngD1ngs
@Matt
Connection holding, but speed dropping dramatically:
31 Jan 2010 @ 23:13 after connection restored:
DSL Connection
Link Information
Uptime: 0 days, 21:53:08
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,120  Smiley
Output Power (Up/Down) [dBm]: 12.0 / 16.0  Smiley
SN Margin (Up/Down) [dB]: 17.0 / 8.0  Smiley
Error Seconds (Local/Remote): 54 / 0
CRC Errors (Up/Down): 12 / 5,612
HEC Errors (Up/Down): 6 / 2,514
Download speed achieved during the test was - 816 Kbps  Grin
DSL Connection Rate :1120 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps  Grin
31 Jan 10 23:15                       925 kbps (116kB/s) 359 kbps (44.9kB/s)
Broadband Speed Checker              Download 904Kbps Upload  332Kbps
Speedtest.net Ping 57ms Download 0.92Mbps Upload  0.37Mbps
and then tonight (I have also tried at various times during the past couple of days with same speed drops):
02 Feb 2010 @ 17:42
DSL Connection
Link Information
Uptime: 1 day, 8:29:42
Error Seconds (Local/Remote): 219 / 0
CRC Errors (Up/Down): 47 / 13,795
HEC Errors (Up/Down): 12 / 6,934
Download speed achieved during the test was - 679 Kbps  Cry
IP Profile for your line is - 750 Kbps  Cry
02 Feb 10 17:46                       626 kbps (90.8kB/s) 354 kbps (44.3kB/s)  Cry
Broadband Speed Checker              Download 712Kbps Upload  279Kbps
Speedtest.net Ping 57ms Download 0.75Mbps Upload  0.32Mbps
What can be causing this and why is my BT profile now at 750Kbps?
jelv
Fixes: 10
The lower IP Profile will be because at some time in the last three days you have synced at a much lower speed than your current speed.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
W1ngD1ngs
@Jelv, so a re-sync early tomorrow morning is in order?  Undecided
W1ngD1ngs
@Jelv, I also forgot to ask about the errors.  Will they be having any effect on this drop?
