broadband capped
- Feedback
- Plusnet Feedback
- broadband capped
broadband capped
26-08-2014 9:08 AM
ive been with plusnet since 2010, been great untill the last 12mths
my line had an upgrade last year , now capable of 3.5meg, was getting constant speed of over 2meg , Now been told cant get over 1.6meg.
PLUSNET not fit for purpose , line now clearly capped even though i pay for unlimited, just a bunch of liars ,
Re: broadband capped
26-08-2014 9:09 AM
If your line has been "capped" then it will be because there are potentially faults on it and the speed has been reduced so you have a reliable connection.
Can you post your modem / line stats on here ? Instructions on how to do so can be found here :
http://community.plus.net/forum/index.php/topic,96155.0.html
26-08-2014 2:32 PM
After looking over your account, I can see your line is running really well and is within your estimate speeds! Having said this, you are due a response from our faults team on ticket 89313818 .
As for what DomS said regarding your mention of Unlimited service, he's exactly right. We can provide unlimited usage but speeds are governed completely by the length and quality of your line from the exchange.
We always aim to get you on the highest speed a line can take without becoming unstable so I can assure you we wouldn't place a cap for no reason
02-09-2014 7:01 PM
my line was upgraded last year and is capable of speeds of 2.5meg max 3.5.
i was getting 2.3 with no problems for a good while , every 2/3 months speed would drop to around 1.2/3meg.
After getting in touch with plusnet speed was back up to 2.3.
after my last session of low speed plusnet sent a complete idiot out who said he did not see how ive ever achieved speeds of 2.3meg basically calling me a liar.
he set my line at 1.8max off wich im getting 1.4/5meg , i think ide call this being capped ,
as soon as fibre is available plusnet will be no longer and from what ive heard i will not be the only one .
as far as im concerned they have got to big to soon and cannot cope with supply thus people like me suffer
02-09-2014 8:09 PM
If you have had unsatisfactory service from BTOR then I suggest you try and make an official complaint about the service they supplied you.
03-09-2014 9:48 AM
I'm sorry to hear that your speeds have dropped slightly. There are so many different variables that can have an affect on speed but as Dan pointed out this isn't done by any sort of capping on our side.
Your acceptable speed range is between 1MBps and 3.5Mbps, you can check this yourself here - http://www.dslchecker.bt.com/adsl/adslchecker.welcome. You are syncing at 1.69Mbps which is within the acceptable range and this is also explained on the Faults ticket.
I'm sorry that you were experiencing faster speeds previously, however, speed isn't guaranteed. Speed fluctuates and estimates are best effort. As your cabinet was only upgraded to ADSL2+ last year it's possible that there's been a high increase in uptake and there are far more connections now than what there were last year causing speeds to dip slightly.
04-09-2014 5:26 PM
you have said what ive been saying all along .you are capping my speed to give to others , you have just admited it ,,,
04-09-2014 5:59 PM
Your speed has reduced because the autiomatic system at the exchange has probably increased the default noise margin
If you can provide the information requested in the first reply to your post we would have a better idea what has happened
04-09-2014 10:53 PM
You just can't help those that don't want to be helped.
05-09-2014 10:23 AM
Some router stats could easily provide some insight as to what is going on.
05-09-2014 10:26 AM
If you want to be helped to get the best possible from your line and are prepared to take the advice of fellow users with a great deal of experience post the information requested here: http://community.plus.net/forum/index.php/topic,96155.0.html
