Wrong limit shown on my account
Gel
Champion
Fixes: 29
When I check the website for my current allowance, instead of showing 10gb, which it has been for ages, I see:
THIS IS YOUR CURRENT BROADBAND PRODUCT
PlusNet Broadband Your Way Option 1 (Annual Contract)£9.99
per month
2GB Usage Allowance
which would be of no use to most customers.
Why does it show wrong usage data, as in box above it says if I want 10gb per month, it'll be £17.99 I recall.
Been 10gb for some time, and at time was + Net response to increasing competition.
I'm on PlusNet Broadband Your Way Option 1 (Annual Contract), and have been with Plus Net many years and well satisfied.
Agree with earlier post about the fact that + Net need to hike these allowances up, even though 10gb is usually OK, as I only get 2mb connection, being on end of long line, with no fibre in prospect, though there is some County initiative to speed the prosepect up.
3 REPLIES 3
bobpullen
Fixes: 330
Re: Wrong limit shown on my account
Whereabouts on our website are you looking?
Gel
Champion
Fixes: 29
Product change
Change your product
Shows current + 2 other options
per month
2GB Usage Allowance=
orbrey
Looks like that's been updated with the change in usage, though I believe the default for Your Way Option 1 is 2GB? If you want a 10GB allowance you could always change to Value from our current product lineup?
