Wish i'd read this forum before I ordered.
- Feedback
- Plusnet Feedback
- Wish i'd read this forum before I ordered.
- « Previous
- 1
- 2
- Next »
Re: Wish i'd read this forum before I ordered.
03-02-2013 6:36 AM
Quote why have you all hi-jacked my thread
For a little light relief.
03-02-2013 1:30 PM
And personally I find your opening post and your latest offensive. They amount to unnecessary shouting.
04-02-2013 6:07 PM
Quote from: peterb99 Just in case you don't know.
You can get a 3 network SIM card from Samba mobile. You then watch adverts and it builds up your free credit to use.
It costs £5 for the SIM (micro or normal) and that's it. It works fine in my old three dongle.
I watched a shed load of adverts when I first got it (just watched them on my laptop while watching TV) and built up 1GB of credit. The beauty is that the 1GB doesn't expire ever (usually they drop off after 30 days). I then just use the dongle when I'm out and about or if my internet at home goes down - its very useful (I ended up buying a 3 network WIFI device which works great with iPads, iPhones etc)
Pete
Fancy #FREE 3G broadband on the go? Use promo code NE199 and get @sambamobile for just £1.99
05-02-2013 5:21 PM
Quote from: Estragon Did it matter, once your problem was solved?
Because the text was larger?? I have sight issues. 10pt as a default is far too small for me to see
05-02-2013 5:25 PM
05-02-2013 6:00 PM
Of your five posts so far, the three large font ones have been when you wished to make a fuss or didn't like what someone else had posted, and the two normal ones have been in response to posts or events you found acceptable.
From that I conclude that your sight problems may be associated with red mist.
05-02-2013 6:10 PM
Quote from: davegraham2013
I find large text quite relaxing to read in a forum
05-02-2013 10:57 PM
06-02-2013 4:27 AM
06-02-2013 8:15 AM
Quote from: davegraham2013 Because the text was larger?? I have sight issues. 10pt as a default is far too small for me to see
Instead of increasing the text size why don't you use the zoom function. That way it will able you to read and post replies and maintaining the same size text.
06-02-2013 9:28 AM
Quote from: davegraham2013 I have sight issues.
In case you don't know (and I'm somewhat surprised if you don't) almost all computer systems have a whole range of facilities designed to assist people with various limitations including sight.
The tools with Windows are comprehensive and if you don't know what they are you should ask whoever supports you with your vision problems to arrange for an advisor to configure your PC to be as useable as possible.
The options mentioned above are just examples and may or may not be the correct solution for you. Someone who knows your specifics and what is available will be well-placed to assist.
06-02-2013 11:12 AM
Quote from: Estragon I find that very hard to take with any real seriousness Dave, whatever your sight difficulties.
Why are you bullying me in this issue? Are you one of those trolls that we hear so much about, just posting for the sake of posting.?
06-02-2013 5:49 PM
I'm sure Estragon is not a bully though.
And welcome Dave!
- « Previous
- 1
- 2
- Next »
- Feedback
- Plusnet Feedback
