Why has my speed been throttled - AGAIN
jojopillo
Re: Why has my speed been throttled - AGAIN
Hi Oldjim,
What email are you expecting?
Jojo Smiley
Oldjim
Resting Legend
Fixes: 63
The one which tells me I have been restricted - I hope I get one with the extra spend set to zero - it is the wording I will be looking at.
The one about approaching my usage allowance was correct
pierre_pierre
A luv letter Cool Cool
Oldjim
Resting Legend
Fixes: 63
Congratulations - you seem to have fixed it - no more mention of 75p per GB
You've now reached the extra usage limit you set for your broadband service. Your broadband service will be restricted until the end of your billing month.
Your extra usage price limit is currently set to £0.
For more information on the level of service you can expect - http://www.plus.net/support/broadband/quality_broadband/speed.shtml
Increase your Usage Limit
You can increase your usage limit if you want more usage - https://portal.plus.net/data_transfer_watch/
View Your Broadband Usage
You can check your usage at any time on our website with View Your Broadband Usage - https://portal.plus.net/view_my_broadband_usage/index.php
jojopillo
Ah, ok I get you now Smiley
Oldjim
Resting Legend
Fixes: 63
and it's happened again despite having an extra £5 spend set - waiting for it to be sorted after a phone call
Dear <snip>,
Account username: <snip>
At the moment your account allows for 10GB of peak-time usage per month.
You've probably noticed that your broadband speeds are slower than usual, this is because you've gone over your monthly usage allowance.  Don't worry, your speed will be back to normal at the end of your billing month.
If you'd like to return to full speed now, you'll need to increase your usage allowance.
There are two ways to do this, you can either:
- Increase your usage allowance - (75p per GB added)
- Use what you like now and pay for it at the end of the month - (£1.00
per GB used)
Update - nearly 4 hours now and still throttled
Oldjim
Resting Legend
Fixes: 63
A weekend with speeds crippled  Crazy
Oldjim
Resting Legend
Fixes: 63
and they still haven't fixed it despite performing maintenance on the account - to say the least I am not best pleased.
Oldjim
Resting Legend
Fixes: 63
For information
The problem appears to be that part of the Ellacoya system thinks I am still on BBYW Option 2 and up to now they have been unable to fix it
This is the last time I will post in this thread until they sort the problem or I reach my billing date on Friday morning which will reset it anyway
jelv
Fixes: 10
I reckon they should give you a free upgrade to Extra in the hope that that will correctly override all the settings and then next month downgrade you back to Value.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Bob Pullen manually fixed it - Thanks
They are going to try Jelv's suggestion
One thing, which I wondered may have contributed to the problem was that I went from BBYW Opt 2 to BBYW Opt 1 10GB special offer to Value and that may have screwed something up.
