Which Is The Best Forum
Selkirk
To post a question on WiFi. Thanks Selkirk.
Steve
Seasoned Pro
Re: Which Is The Best Forum
No need to ask, A Moderator might kindly move this topic to the right place then you can fire away.
Edit Failing that If Its a Plusnet router then I think you could ask on this section...http://community.plus.net/forum/index.php/board,3.0.html
If life gives you lemons, make lemonade.
Fixes: 62
Depends on the problem.
If it is a router problem then Broadband and Routers board but if it is Windows then the Windows board but if it relates to Xbox or PS3 then Gaming may be a good idea.
Alternatively post it here and a moderator will move it
Selkirk
Thanks will try Broadband and Routers, As you say Mod will move if wrong. Selkirk.
