When will my MAC arrive
pierre_pierre
Re: When will my MAC arrive
Me  Roll_eyes  well on Value, Market 3, last time I looked over 20 days up time, and
Your DSL Connection Rate :16492 Kbps(DOWN-STREAM), 908 Kbps(UP-STREAM)
IP Profile for your line is - 15000 Kbps
Jaggies
You should only have a 14000 IP profile with that synch rate.
pierre_pierre
thats what the BT test just told me
and I get just under 14000 from my Samknows monitor
Jaggies
IP profile may not have caught up yet - put your synch rate in here.
(Edited to correct link)
pierre_pierre
Who care more than fast enough for me, I could get FTTC if I was worried,
Luzern
Fixes: 9
Quote from: pierre_pierre
FTTC
Does FTTC = Flustered to the Core? Grin
Jaggies
It's just that your synch is in the same range as mine, and my profile is 14000 - fast enough for me, too...  Cheesy
No FTTC here, though...  Embarrassed
pierre_pierre
router stats
Link Information
Uptime: 6 days, 15:20:57
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 910 / 16,495
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.0 / 21.0
Line Attenuation (Up/Down) [dB]: 9.5 / 20.0
SN Margin (Up/Down) [dB]: 8.5 / 4.0
Vendor ID (Local/Remote): TMMB / TSTC
PN profile
Phone exchange:
    BRAINTREE
Estimated line speed:
    8Mb (Accurate to within +/- 1Mbit) - Checked on 2009-08-09 03:31:10
Current line speed:
    15 Mb
You are currently connected to the gateway known as thn-ag1.
This is located in Telehouse North
seem to have changed around the 9th Same results have gone up
pierre_pierre
mind you the Beeb are doing a survey, dont know how they get their figures
http://www.bbc.co.uk/news/uk-england-12430744
clicked on here
Broadband users can test their upload speed on BBC News' Technology website.
got this http://news.bbc.co.uk/1/hi/technology/8172065.stm
Your connection to bbc.co.uk is working at 6.5 Mbps.
At this speed it would take you less than a minute to download a 4 minute song and under ten minutes to download a half hour TV programme.
then went here
Home broadband users can take part by plotting their speed onto an interactive map. I put in my sam figure and ended up on the map with the light coloured high speed bit in the middle
http://www.surveymapper.com/mapView.aspx?id=172
