Whats with the double speak ?
BorgWales
There's no limit on how much you can use, but once you've used your 10GB allowance, additional usage is charged at £5.00 per 5GB.
So if I have no limit how come you keep telling me I do ?
And the usage info is very confusing.
7 REPLIES 7
magnetism2772
Re: Whats with the double speak ?
Hi BorgWales
I'm on the plusnet 'value package'  but it has a maximum  usage of 10Gigabyte per month
things change at midnight when you can download all you like untlll 8 AM in the morning
plusnet do have unlimited usage but its in  their top of the range business package
@ http://www.plus.net/business/broadband/
option 3
198kHz
Fixes: 42
Quote from: BorgWales
Seems quite clear: Your monthly subscription includes 10GB of usage, but you can pay for as much extra as you want.
BT technician (Retired)
nadger
@ BorgWales - As it says there's no limit to how much you can download but you'll pay more ( £5 per 5Gb) if you go over the monthly allowance for your Value package, between 8am & midnight - midnight to 8am is unlimited.
BorgWales
Its all these bloody Win7 Updates
pierre_pierre
get your nightcap out and do them after midnight then
Fixes: 580
OR get up early at the weekend and do them before 08:00.
Steve
Seasoned Pro
Or change to Linux, Must say I dont have a load of windows 7 updates since its release, 33 in total!!
If life gives you lemons, make lemonade.
