What an excellent business plan!!
- Feedback
- Plusnet Feedback
- What an excellent business plan!!
Re: What an excellent business plan!!
10-02-2009 4:36 PM
10-02-2009 4:38 PM
Quote from: Sunny Hi, BT master socket is in the loft even though the house is only 5 years old they put it there so it is difficult to get access just for testing but I have done it. The extensions run from that to each room and all filter are fitted. No Sky just a telephone connected. Router is connected downstairs.
I do not understand what SNRM means sorry but thanks fo rtrying to help really appreciate trying to get to the bottom of it. Currently Noise is showing 9.2 on router stats.
Router is Netgear DG834GT I have no idea where to finds the up/down power level sorry.
OK.
SNRM is Noise Margin by another name.
DG834GT doesn't show power levels easily, though if you run DMT against it you can see the numbers.
I suspect your extension wiring isn't helping and may be picking up interference.
Personally I would tackle that first by optimising it, what do the other "advisers" here think?
10-02-2009 4:41 PM
...and Routerstats also sometimes calls it "RX Noise" as in oldjims training session...
10-02-2009 4:42 PM
Quote from: Oldjim Click on Telnet Router
Is that Routerstats version dependent? I've got 4.7b (and a DG834GT) and it's not an option.....
10-02-2009 4:45 PM
10-02-2009 4:50 PM
Quote from: Oldjim That is the sync speed what we want is this
Click on Telnet Router (you may need to enable debug mode first - if so just click on this link which will do it. It will then stay enabled unless the router is switched off or rebooted.
Hi again I have done that and here is the first picture. The other pages are not showing any graphs but I noticed the timeline is set to 1 hr 23 mins a page where yours seems to be at 15 mins,
10-02-2009 4:58 PM
If you click on the funny symbol - top left - looks like a yellow gear wheel that gives you the set up screen
Then click on graphs and you can change the sample period and number of points
This is what mine looks like
Edit - the 15 minutes is measuring the number of error in about a 15 minute interval then plotting it - note the times on the bottom
10-02-2009 5:01 PM
Quote from: Oldjim That is probably because you are running Routerstats Lite
No it's because it appears to be turned off by default in my version. Works fine if turned on!
10-02-2009 5:04 PM
Quote from: Sunny Hi again I have done that and here is the first picture.
Those look reasonably OK.
I still stand by my earlier assertion that your extension wiring is probably a significant factor.
How many extensions sockets are there in total and in use?
10-02-2009 5:11 PM
Look at this picture - the corrected errors and error seconds are appalling.
I would agree with HPsauce - your internal wiring is probably causing major problems.
Is there any chance of moving the router next to the master socket and either going wireless or using a long lead from the router to the PC
10-02-2009 5:21 PM
Quote from: Oldjim Sorry to contradict
Not knowing the up-time I didn't look at the error rates.
Stats from the Test Socket time methinks, awkward though that may be.
And to think about a filtered faceplate with ADSL take-off.
10-02-2009 5:31 PM
Quote from: Oldjim The graphs only start when you enable them by ticking each individual box - it doesn't start doing them until you tell it to.
Done that Oldjim,
I have just closed R/S down and reopened it to see if the stats appear and done a shot of the pages for you here, dont know if that would help you?
10-02-2009 5:33 PM
10-02-2009 5:36 PM
10-02-2009 5:37 PM
Quote from: HPsauce
No contradiction, I only looked quickly at the speeds, margins & power levels.
If it must be done it must be done, I will go into the loft tomorrow morning when I have the day off and set up the router direct to the master socket. Could someone please tell me what statistics I need to report back once I have done that? If needs be, how to get those stats off Router stats.
I have a long lead no problem so I can use that.
Thanks to all who are trying to help me with this, you all have greater knowledge than me I am sure.
What do you mean by a filtered faceplate? There is only 1 ext socket in use in the house for the telephone, nothing else is connected.
