We Need Better Fault support and no DLM please
- Feedback
- Plusnet Feedback
- Re: We Need Better Fault support and no DLM please
27-05-2010 12:36 PM
I have a fault with my service constant disconnections etc. I was patient and went through the motions after a week and 3 Days I contacted CS who said that the banding can now be removed. because i had 72 hours of solid connection
This was done done, and my connection rate was "Normal" but the BT profile stayed the same for 2 days I contacted CS to inform them and was told that I have wait 3 for the profile change!!!
As soon as I put the phone down. MY BB disconnected and I am back on a Banded Profile. I phoned back and tried in vain to speak to someone in the faults team but they don't talk to customers. any I was told that they would call me. which means waiting like a Muppet for another two weeks. there should be a contact number for customers who have faults that have been escalated. 9 times out 10 the tickets are NOT updated when I call CS if the CS REP doesn't update a ticket when I call how the hell can problems get sorted. or is it company policy to fob people off now
I have ad it with DLM. Any suggestions for a good LLU provider.
ticket ID: 33408428
27-05-2010 12:41 PM
27-05-2010 12:58 PM
AOL:
O2 / Be:
C&W / Bulldog:
Orange:
Sky / Easynet:
TalkTalk (CPW):
27-05-2010 1:00 PM
I've just dropped a quick reply to your other post - one of our faults guys is looking into this for you now.
27-05-2010 1:53 PM
The faults team are talking to me now
27-05-2010 2:03 PM
27-05-2010 2:46 PM
Andrews & Arnold not sure about them If you're on a BT Backhaul with them you inherit DLM
TBH Plusnet did raise reservation about DLM in particular Banded Profiles to their "Provider" as I recall it seem to fall on deaf ears.
In this instance my frustration is with the Providers provider BTW.
27-05-2010 2:52 PM
I believe Rami managed to get BT to turn off your line banding again. Hopefully it'll stay off for a bit longer this time!
27-05-2010 5:34 PM
Quote from: ctech500 Andrews & Arnold not sure about them If you're on a BT Backhaul with them you inherit DLM
A&A give the choice of BT or Be - with Be the base cost is higher, but you get far higher allowances and additional usage is a fraction of the cost.
(Incidentally they also charge a lot less for people on 21CN connections than those on 20CN. ISPs who are shifting loads of people over to 21CN and then still charging the same are making a nice profit!)
27-05-2010 9:06 PM
- Feedback
- Plusnet Feedback
