View My Broadband Usage
MKen
Is this broken?  all I see is a message
Sorry, there's nothing to show at the moment.
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 4 hours for your usage to show up - please try again later.
Was same when I tried yesterday as well.
30 REPLIES 30
MatthewWheeler
Fixes: 503
Re: View My Broadband Usage
As far as I'm aware there's no issues with it.
I'll check with the relevant people in the morning.
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
alext05
Well, I can access my usage but... I see large zeros for yesterday and today. What's going on?
MKen
Quote from: Matthew
BlackPearl
Yes it is broken , I have had no usage information since I joined last November and they can't fix it
for my account !
I seem to report this at least every month or so but it never gets fixed.
drunkenmonkey
Hmm looks all fine here, usage looks a little lower than expected however all the numbers are populated
spraxyt
Resting Legend
Fixes: 75
Quote from: MKen
Is this broken?  all I see is a message ...
You could try disconnecting from Plusnet using your router's admin interface, then reconnect again. This will start a new PPP connection which sometimes prompts VMBU to start recording again.
Note, this will not lead to missing usage being filled in, the current zeroes will stay as zero.
David
MKen
Seems to be working now - though showing a couple of weeks of zero usage
Heanorman
My ''view my broadband usage'' hasent been working since yesterday wednesday. First time it hasent worked in 6 years.
Just done an online chat about it, but not sure if she knew what i was on about. Still dont work.
kitz
I reported it as broken on 30th of June as mine went AWOL after my last billing period (19th) and not re-appeared since.
I was told they were aware of the issue and that it didnt matter because I was on an unlimited product.   I was also told that it had been broken for a while and  they would likely be doing away with VMBU all together.
Name removed - CSC Analyst
8:06pm, Tuesday 30 Jun 2015
Chat reference:4304833170
Description:Added to Problem 84083 regarding no usage showing.
So from that you can clearly see that there is a known issue with VMBU and they are aware of it.
I asked why there wasn't an SS about it, but the impression given was -  its broken but didnt matter and unlikely to be fixed Sad
Mayfly
All Star
I first had problems with it in November 2013 and it regularly crops as a problem on here.
Mad_Moggies
Not just me then! Just thought I'd take a look and found the message that either my account is new or it's the start of a new billing period, neither of which apply to my account. Not too much bother as it's unlimited but I was wanting to check how much bandwidth something had been using.
Plusnet user since November 2003
Full Fibre since September 2023
Mac OS and Firefox user with latest versions of both
mojorisin
I have had the same message since adding plusnet tv to my package
Saturn
My Usage monitoring stopped working 15 months ago and I first got the "were on it" statement then the same as Kitz "you don't need it anyway".  It wasn't this apathetic when I joined PlusNet 13 years ago.
jelv
Fixes: 10
I've a feeling whether it works or not depends upon which gateway you are on. Until my gateway changed yesterday I was on pcl-bng02 and VMBU wasn't working. I'm now on ptw-ag01 and it is working.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
