VPN issues
skxxx
VPN issues
Hi - switched to PlusNet a week ago and on the whole all is good.  However - one biggish problem is that the VPN I use for work won't connect (it was fine with BT).  I've tried all the suggestions on previous forum posts, firewall set to low (and also tried it off), various commands via telnet but to no avail.  I'm using the free router supplied - is it possible to use a VPN with this? Or do I need to get a different router?
4 REPLIES 4
Jaggies
Re: VPN issues
Check your firewall setting here - https://portal.plus.net/my.html?action=firewall (you'll need to log in)
If it's set to "High" then that's what's blocking your VPN.
w23
Fixes: 4
Re: VPN issues
If you still have your BT hub most versions, if not all, can be used on Plusnet broadband.
Call me 'w23'
skxxx
Re: VPN issues
I do still have my hub - so will give that a try! Thanks.
dick:quote
skxxx
Re: VPN issues
Now up and running with Bt homehub - thanks W23.
