VMBU still not reset!
mrmarkus1981
Its been about 10 days since my switch to extra and my vmbu has STILL not showing any usage.
Despite a response to my ticket saying 'not to worry' i will NOT be hel responsible if i go over 60GB this month!
8 REPLIES 8
Chris
Legend
Fixes: 169
Re: VMBU still not reset!
Sorry about that, I've checked and found a few other accounts in a similar position so have raised an internal problem for investigation.
I'll put a ticket on your account with your daily upload/download since your billing date so you can see how much you've used so far.
Chris
Legend
Fixes: 169
Just to clarify this, it's not that the usage isn't reset, it was the usage not appearing at all on VMBU.
It's now fixed and should appear as normal.
fixed under problem 61653
pierre_pierre
I now have this problem, But I have not changed anything on my account, last bill 23 Jun, no VMBU report since
Chris
Legend
Fixes: 169
Can you try a disconnect/reconnect on your router and then take a look at VMBU around 2 hours later? I've got a feeling that should fix it.
I can put the usage since your last bill on the ticket if you'd like so you can see how much you've used daily?
pierre_pierre
please Chris
When you say disconnect, do you mean a router power off or software disconnect?  - my uptime was 13 days, but have changed gateways recently
Just done a software disconnect
Chris
Legend
Fixes: 169
VMBU is showing up now for your account.
pierre_pierre
oh well another of those little things, Yes OK and back to start of period Ta
bobpullen
Fixes: 330
Have a read of my post here that explains why this happens (in particular the bit at the bottom in italics).
