Usage Limits & Speed
- Feedback
- Plusnet Feedback
- Re: Usage Limits & Speed
23-08-2009 9:35 PM
P.S. Exceeding the 20gb usage limit is very unusual for me, its just its the holidays etc so yeah....
24-08-2009 2:09 PM
As you're on Broadband Premier, that put you onto Management Level 3. That should mean that you get about 500Kbps on your normal web traffic.
If you're thinking about sticking with us for a while, have you considered looking at our Unlimited product?
24-08-2009 5:50 PM
I find the usage restrictions to be highly detrimental on browsing activities so I'm now kind of concerned that something is wrong with the line or restriction settings on the account. Over the last few days we've been getting quite a lot of disconnects in the household as well. Is there any chace you could look into this?
Thanks some more
24-08-2009 8:13 PM
Are we talking about wireless dropping or the actual connectivity to the internet entirely?
Could be related to the poor speeds if the latter.
24-08-2009 9:42 PM
24-08-2009 9:45 PM
Quote from: xiphlol Connectivity entirely, the computer downstairs has the router next to it and is wired in. The windows fault checker shows everything being active except with no internet connectivity. I think a family member also mentioned that one time this happened, the router didnt even register there was a problem (no red light 😮 ). I used a speed checker mentioned in another thread and the reults came back at about 130kb/s. I'll go run it again now.
Earlier today:
Just now:
In the earlier one I also noticed that the progress bar stopped moving for about 10secs halfway through (i.e. no download occuring :s )
Hopefully I'll have time to run one after midnight as well, or tommorow morning failing that.
Edit 2:
25-08-2009 1:11 PM
25-08-2009 1:19 PM
Can you try:
- Changing filters
- Using different router
- Connecting your router into a filter, directly into the test socket behind the master faceplate (if you can't do this, use the master socket with all other telephony devices detached).
Let me know how you get on.
25-08-2009 1:43 PM
25-08-2009 1:53 PM
25-08-2009 2:08 PM
26-08-2009 12:32 AM
26-08-2009 9:06 AM
I've attached the results to this post. It definitely is better, but the upstream sync speed should be 448Kbps rather than 256Kbps. I suspect that your line may have been profiled like that because of the previous problems.
Can we leave it for a couple of days to see if it corrects itself automatically?
26-08-2009 9:23 AM
if you have a Thompson router this link will take you there http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0 otherwise check here http://www.kitz.co.uk/adsl/frogstats.php
Quote from: xiphlol I would if I knew how! Is there a sticky somewhere on how to find out these things?
26-08-2009 9:27 AM
If you're on Premier 1 be aware that if you go over 20GB a second time then your line speed will be restricted 24/7 until you upgrade your package.
I assume that this hasn't changed since the product refresh and that an upgrade to Premier 2 would not be available?
Forum Moderator and Customer
