Upgrade to fibre
oldbaldeagle
Upgrade to fibre
We were due to upgrade to fibre today, and I have to say that reading all the horror stories on here I wasn't too confident it would happen.
However, I'm pleased to say that the Kellys' engineer turned up in the allotted time slot; he rang to say he was on his way and arrived when he said he would.  He did a good tidy job with absolutely no mess and wouldn't leave till I had ensured that I was able to connect to the internet.  This is the 2nd Kellys' engineer to have been here since we moved in and both have been exemplary.
I've just done an Ookla speed test and it showed 35mbps, which is massive improvement on the 6.5 we had before.  Hopefully there will be no issues going forward.
A big thank you to all concerned  Cheesy  Cheesy
1 REPLY 1
adamwalker
Fixes: 223
Re: Upgrade to fibre
Sounds good!
I shall pass on some feedback.
 Adam Walker
