URGENT - Question ID: 31710672 can someone at Plusnet chase before 5.30 today?
- Feedback
- Plusnet Feedback
- URGENT - Question ID: 31710672 can someone at Plu...
22-02-2010 4:44 PM
Re: URGENT - Question ID: 31710672 can someone at Plusnet chase before 5.30 today?
22-02-2010 4:48 PM
22-02-2010 4:52 PM
22-02-2010 5:04 PM
23-02-2010 1:09 PM
Nobody from BT has called or emailed to tell me otherwise and I have no idea if/when the engineer will turn up.
I bet if I started billing BT at my work hourly rate they'd be here sharpish.
23-02-2010 1:48 PM
I've just had a look at your fault following this post and can see a sudden flurry of notes has been added (though there's no detail, just notes to say 'KCI activity' and 'repair in progress') which I suspect means that an engineer is either working on it from the exchange or possibly at your premises - have you seen anyone at all?
Please let me know if not and I'll call up and chase this straight away for you.
23-02-2010 1:59 PM
[EDIT]My other concern was that they may still turn up tomorrow as the days I requested included tomorrow - I was informed this would not be the case but a check was also being done to make sure that the dates are correct with BT. [/EDIT]
Benjamin
23-02-2010 2:29 PM
23-02-2010 3:09 PM
Benjamin
24-02-2010 12:04 PM
Quote from: brownb2 I guess it could be worse.
I lost all phone and broadband for 30 minutes after the BT engineer left - that got me panicky the missus likes her flash browser games on an evening (and work might not appreciate me not VPN'ing much).
Both seems to be back now and sync'd at 6327 - I'd like to think it was the panicky message I left on the support call question but it was probably the engineer or an automated system!
[UPDATE]BT engineer must be pushing buttons now - sync'd at 8240 for a while then disconnected. Thank goodness for emergency 3.5G mobile broadband [/UPDATE]
[UPDATE 2]BT engineer called back and router had sync'd at 8946 - he's lowered the noise margin again. Actual download throughput seems to be about 350KB/s (i.e. worse) but I'm happy to sit on it for a bit and wait for the noise margin to become more realistic (probably about 9dB) and let the profiles adjust themselves. [/UPDATE 2]
24-02-2010 12:32 PM
- Feedback
- Plusnet Feedback
