Traffic Prioritisation Problem
- Feedback
- Plusnet Feedback
- Re: Traffic Prioritisation Problem
31-10-2014 9:26 AM
I know it is my problem
But downloading from Megadrive kills normal browsing presumably because it doesn't use a normal download method and uses encryption
3 REPLIES 3
31-10-2014 12:54 PM
Hi OJ,
Is this in reference to mega.co.nz?
If so, Dave has just confirmed that traffic to and from Mega should be detected as SSL and will be treat the same as HTTPS in the Gold queue.
31-10-2014 12:56 PM
yes it is
31-10-2014 1:07 PM
Thanks for confirming Jim,
As they'll be given equal priority I suspect this is why you'll be seeing the drop on browsing while downloading from Mega.
