Top Quality work
HarryB
Fixes: 256
Re: Top Quality work
Thanks for the PM Nick.
Unfortunately I can't raise this with Openreach  Sad
When you said Kelly's on behalf of BT I assumed you meant BT Openreach, but looking at the account it's your phone provider.
If it has already been logged with them I hope they can sort it out for you  Smiley
 Harry Beesley
Fixes: 246
Quote from: Estragon
Kelly's and Quinn's are the two subcontractor telecoms engineer firms Openreach took on when the demand for FTTC installations overwhelmed them quite a long time ago.
The horror stories are legion :(.
They certainly are for Kelly's cowboys, however the only stories I've heard in respect of J. C. Quinn have been for their excellence.  I had a J. C. Quinn guy turn up to a job on Wednesday morning - setting aside that BTOR should never have allocated the job to a sub-contractor, my only grounds for complaint would have been that he did not have the right gear (fibre glass ladders) for working on a joint services pole.
MattyC
Fixes: 46
To add some contrast; Kelly seems to get sourced a lot in Sheffield, as I've had a Kelly engineer every time. They have always done a decent job.
Mayfly
All Star
Ditto Matty - it was a Kelly engineer who installed my fibre and he was courteous and polite and did a good job.
