This is poop, and I've had enough now
Anotherone
Champion
Fixes: 21
Re: This is poop, and I've had enough now
@Scotland
read reply #2 above and the links in it. Also it looks as though you may have developed a line problem. Try starting a post on the Broadband speed board and post your line stats.
@stormrunner
please try what Mand has suggested and then raise a thread on the Broadband speed board and post your line stats as well.
@Pugs
Please do the same & are you aware about traffic shaping http://www.plus.net/support/broadband/quality_broadband/speed.shtml#residential
@AllenC
If you still have problems, please do the same.
stormrunner
ok did the fault question thing  ran the 3 tests on the Bt checker which is giving me a realy good set of stats,
got up this morning and tryed downloading some files and got realy good download speed, 700kbs+ for a short while  then it was like someone fliped a switch and now im getting little over 70kbs.
took some screen shots of the bt tests and some of the tests i did at another site as well as some of the downloads i did but not sure how to post them on here
so now i have to wait and see what plusnet come up with to my raised question...
Undecided
ok added 2 shots from the BT checker
1 from another site and a shot of my download speed
and plusnet have replyed to my question  but they seem  not to be too sure whats going on
Mand
Can you copy the results into here?
Or use the additional options section when posting and attach the files.
Oldjim
Resting Legend
Fixes: 63
To post pictures on here select the Additional Options at the nottom
Scotland
Plusnet.  My BT results are Download - 641 kbps d/l (60.1kb/s)    and  Upload -229 kbps (28.6kb/s)
Scotland
The aove results were on the day I had posted.  Todays speed is much faster but it usually is during daytime.
Download speedachieved during the test was - 3007 Kbps
Additional Information:
Your DSL Connection Rate :5600 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
I will post results again at evening time.
