Surprised and disappointed with Plus Net
- Feedback
- Plusnet Feedback
- Surprised and disappointed with Plus Net
11-11-2009 9:13 AM
On moving to Plus Net I was straight away plagued with intermittency. I reported this to the help desk and was passed about 1st line support for a couple of weeks. In the end I “resolved” the intermittency myself by installing a new router and setting the idle timeout to zero, thus forcing an immediate reconnect on drop out. I didn’t receive any advice to this affect from Plus Net support. Perhaps if they’d done so I might have saved the cost of the new router.
Since moving back to Plus Net I have never been able to obtain a faster service than 0.7Mpbs downstream. I have become very frustrated with the support service and their apparent lack of any attempts to resolve this. I raised a fault about the problem. After being passed about now for weeks I was told to raise a fault. I attempted to do so only to be told that a fault was already open.
In response to hopeless suggestions by the help desk I have been unscrewing telephone plates, running cables up the hall to the master socket and trying to find a non existent test socket. It would be comical if it weren’t so frustrating. And it’s not just a theoretical problem. I can’t use BBCi Player any more and many of my other online activities are severely restricted. As a photographer this is a real problem for me.
Now the fault appears to be closed, there is no improvement in the service and the help desk will not communicate with me about the issue. It’s very poor customer service.
And in anticipation of being told that because of my line conditions I will not be able to receive more than 1Mbps downstream I would point out again that I consistently obtained about 1.8Mpbs from Sky. And so I did when I was last with Plus Net. So it can be done.
The ticket in question is 30124844. I can’t think of any alternative now but to refer it to Ofcom.
Re: Surprised and disappointed with Plus Net
11-11-2009 10:32 AM
1. What https://portal.plus.net/my.html?action=stable_rate says for your current line speed
2. The results from the BT speedtest.
3. The stats reported by your router, including specifically sync speed, attenuation and noise margin
11-11-2009 10:48 AM
Stable rate:
Estimated line speed:
1.0 - Checked on 2009-09-25 14:00:45
Current line speed:
1000
BT Speed Test
FAQ
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
684 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speed achieved during the test was - 684 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :832 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
Router
Modem ADSL Firmware Version A2pB022c.d20e Modem Status Connected DownStream Connection Speed 832 kbps UpStream Connection Speed 448 kbps VPI 0 VCI 38
11-11-2009 12:14 PM
We really need the attenuation and noise margin figures as well as the sync speed please. http://www.kitz.co.uk/adsl/frogstats.php has instructions for lots of different modems/routers. If yours isn't there please post the make and model and I'm sure someone will tell you how to get them.
Have you got more than one telephone extension in the house (even if not in use)? If so could you describe your setup including what phone handsets, cordless base units, sky boxes, in fact anything that is plugged in to a phone socket, including where you have filters please.
11-11-2009 12:19 PM
11-11-2009 2:07 PM
11-11-2009 2:11 PM
11-11-2009 2:12 PM
11-11-2009 2:28 PM
11-11-2009 2:30 PM
My slow speed issues is still not resolved. I doubt it you guys will resolve it before I migrate to vivaciti - Yes im advertising them as well!
11-11-2009 2:33 PM
Can I just say in advance that I will be away on business for much of November and unable to monitor the performance until I return.
Thanks James!
11-11-2009 2:35 PM
Thanks for your time on the phone.
As I mentioned, I believe that your speed problems (whilst compounded by a long telephone line) are related to the 12dB target noise margin assigned to your telephone line by BT on account of your first router being faulty.
I'll get a request submitted to them to reduce this to 9dB initially now and we'll see how stable your line is then.
11-11-2009 2:36 PM
As mentioned before in one of your other threads - there's nothing I can do for you as I want to try and place an order on your line, which I can't because you already have an outbound migration request. I wanted to help, but I couldn't because you had already placed a migration order.
25-11-2009 9:32 AM
I'm back from my trip and I don't see any improvement in the line speed. It actually seems to have got worse. I am only seeing 640kbps at the router this morning.
Have you done everything you said you were going to organise? If so I think it's time for me to make alternative arrangements.
Look forward to hearing from you.
Regards
Ubi
Quote from: Jameseh @Ubi
25-11-2009 9:35 AM
