Speed estimate welcome letter
drmiket
I've read several posts on the forums now that mention people getting a welcome letter as below.
Dear Mr ***********
Account username: *************
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
I never received such a letter. Do you have that info, i.e. the speed YOU expected my line to be BEFORE I started using the service?
thanks,
Mike
PS Am asking here because the ticket system is sinking under the weight of current problems
8 REPLIES 8
pjmarsh
Fixes: 24
Re: Speed estimate welcome letter
You can see the estimated speed on this.  It's updated every so often.  Mine has a last updated date of 16th December 2009.
Phil
Chris
Legend
Fixes: 169
Phil has given you the link to show the info you're after. If my memory is correct, we didn't start sending those emails out until October last year (although I could be off on that).
drmiket
Thanks for the v quick response. Am sure you've guessed why I am asking but let me elaborate.
I joined in June and everything just worked so I never checked "how fast is my line today" like many people on the forums here. Then late November my connection became unstable overnight i.e after midnight it went bonkers, bouncing the router so I raised a fault. BT's DLM saw this and cranked the dial up to "bad line, let's go really slow". The result of that is SNR is at max 15dB and my line speed is a puny 1.5-2MB/sec.
Sooooo I would like to return things to normal, as in the SNR back to 6dB and thus potentially get the maximum speed that the line can manage. I have asked support to put the line back in "training mode" but was told "it's not possible". I know it IS possible because a work colleague who also uses PN told me to ask for that specifically.
In short *if* my line started life at 3.5MB I'd like to get back to that speed. Ideally I'd like something closer to 8MB like everyone else but am trying to be realistic! The main problem is I've no idea what the Maximum Stable Rate was back in June-Oct so don't know what my target is.
thanks
Mike
Mand
Resetting the SNR is possible, but is more difficult on your line as on the standard Max lines, as you've been moved to 21CN (it's a manual process at present).
I've got someone looking at this for you now, it will get done, but due to the manual work required may take a little longer than usual.
drmiket
Hi Mand,
Many thanks for that. I don't mind if it takes a bit longer than normal.
The current stats are not good. I am sure the line can handle more than that.
Estimated line speed:
2.0 - Checked on 2009-12-10 13:27:02
Current line speed:  1250
Mike
Mand
This has been reset to 6db now. Smiley
drmiket
So I see. The speed has doubled accordingly  :D. Many thanks Mand.
Mand
Good to hear. Smiley
