Someone from Dev been tinkering ..... ??
matt_2k34
OK didnt really know where to put this
and as such - i haven't found anyone else saying it (I could be wrong??)
But theres a "Test Pro- Addon" on the add ons via membercenter?
Pic Related Wink
Cheers
21 REPLIES 21
Oldjim
Resting Legend
Fixes: 63
Re: Someone from Dev been tinkering ..... ??
Moved to Feedback as I have the same thing and also noticed this - can someone note that I don't actually want spam or viruses  Grin
Also what are the others in the list
matt_2k34
Thanks for the nudge over Jim.
Wonder if it will create a headache if someone adds it to their account....  Crazy
helliewm
Test Pro Addon and Pro Addon
What is the difference between the Test Pro Add On and Pro Add on? I have subscribed both but suspect I only need one of them.  I work from home so the 2 things that influenced by decision to join Plus Net was the Static IP and the Pro Add On but how does the Test Pro Add On differ to the Pro Add On?
Oldjim
Resting Legend
Fixes: 63
post merged into existing thread
Chris
Legend
Fixes: 169
Yikes! Please don't subscribe to the test add-on, it shouldn't be there.
*goes to raise a problem and get it removed.
Problem 67651
Fixes: 1,495
[me=dvorak]subscribes quickly to see what'll happen[/me]
Chris
Legend
Fixes: 169
You'll get charged, that's what will happen!
We'll refund anyone who's added this btw.
matt_2k34
Excellent, thanks for raising that Chris.
Any idea why its appeared? someone been playing with replicating issues with the Pro addon not being added, and its been published live, rather than internal?Huh
Chris
Legend
Fixes: 169
someone been playing with replicating issues with the Pro addon not being added, and its been published live, rather than internal??
Bingo. There was some testing on issues surrounding the billing and profiling of the Pro add-on which is why the new test add-on was created. Unfortunately this was put live and around 10 people added it. We're removing it and sorting out the upcoming bills to ensure they don't get incorrectly billed.
matt_2k34
Nice to know its sorted Chris Smiley
Regards
scootie
so how does this work then with pro add on (not the test one) 11.49 on value with 10gb cap and 16.49 on extra 60gb cap. so you have done away with the stand alone pro package at 20gb for the what i remember 19.99 or near about.
seems to good to be true to have no lower than  gold priority on 60gb for £17 a month, i remember the pro boys an girls begging for usage increase and they was paying alot more for it to.
is this aloud on a fttc 120gb(from memory again) connection as well? holds VM contract in both corners of the page waiting for reply
Oldjim
Resting Legend
Fixes: 63
YES
Easy way is to look at the product comparison tool http://usergroup.plus.net/prodcomp1.php
matt_2k34
Its quite a good deal imho.
Just cant justify the extra - on the Fibre packages 20/10 meg cabs are more than double what i used to get... when i start feeling fibre isnt quick, ill probs add it  Roll_eyes
rongtw
Fixes: 12
to be honest i did try the pro add on for a while  Wink and found i had absolutely no difference in my connection  Huh i do a lot of gaming online which it supposed to give a higher priority but was exactly the same as just the basic package , which i have .
so it was a waste of money for me  Undecided
