Showing results forΒ
Search instead forΒ
Did you mean:Β
So far so good 😊
Chrisvesey
So far so good 😊
Joined plusnet at about 12.30 on Friday, new router arrived Saturday lunchtime. The complaints concerning contacting customer service are exactly the same as jl, I never did get a reply to my last query. Pl are slightly cheaper and do the Internet TV which we want. Change day is the 30th, wish me luck
7 REPLIES 7
Fixes: 1,664
Re: So far so good 😊
Hi @Chrisvesey, welcome to Plusnet and our community forums.
I've been looking into your order today and I've added a reply to your ticket for you over Here.
Chrisvesey
Thanks for your help, is there any way my services can be transferred without losing services for any time, it's ok if it happens before the 30th
Fixes: 1,664
I've picked up and updated your ticket for you.
Hope this helps.
Chrisvesey
Thanks for your help, could you possibly phone me to clarify things, tried phoning but unable to get through 😞
Fixes: 1,664
Thanks again for your time on the phone @Chrisvesey
I've updated you via your account following our conversation, and I'm keeping an eye on this for you.
Chrisvesey
Now the proud owner of two plusnet routers 😁 same thing happened with john Lewis but the first one didn't work so I'll hold onto both until everything is up and running. Any idea how long it takes to set up the account? I know the bank details are OK as the money has gone out,
Chris
Fixes: 1,664
Cheers again for your time on the phone Chris.
As discussed, I've got everything set to transfer over on the 30th, and I've emailed you with more information opening a support ticket which you can view and reply to from here.
Two is always better than one. Smiley
Let me know if you have any further queries.
