Self install Fibre due at end of the month, you ready for it?
Gus
Simply are you planning on doing self installs with a all in one modem/router?  I am asking as the lure of fibre is getting stronger and I remembered that you were testing a Technicolor FTTC router/modem combo a few months back after seeing the news that self install is due
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
64 REPLIES 64
rongtw
Fixes: 12
Re: Self install Fibre due at end of the month, you ready for it?
will PN be supplying a new all in one FTTC router ?
AndyH
I'm sure they are planning it and it will happen. They've been testing self-installs with staff I believe.
MattyC
Fixes: 46
Hi guys,
At the moment, there's no news of this.
No doubt we will let you all know as soon as this is possible.
rongtw
Fixes: 12
if you do MattyC i would like to be first in line  Wink
be nice to have just one box rather than 2
MattyC
Fixes: 46
Quote from: rongtw
It would make our lives here so much easier as well  Cheesy
tijara33
Fixes: 6
Will this news make any difference?
FTTC self-install gets the full commercial launch tick on 29th September
http://www.thinkbroadband.com/news/6612-fttc-self-install-gets-the-full-commercial-launch-tick-on-29...
adie:orange fixed url
Gus
tijara33 no, as its the same link I posted
AndyH
Plusnet are probably trying to get rid of their TG582N stocks before moving over to self-install. They've also got to make sure whatever kit they choose for self-install works ok (hence the modem bank/staff testing).
pwatson
Just as long as PN plan to have a config for the TG589 (or any other chosen CPE) to run it in bridge mode (aka 'modem only' mode) for those that wish to use alternative routers.
Oldjim
Fixes: 63
or the option of staying with the BT Modem install option
Timalay
While I've not had any huge problems with the Technicolour router supplied by Plusnet (Apart from the 1st failing 9 months in, second still working about 10 months on now).  It would nice to have all in one modem/router would be nicer (also save a plug on my surge protector).
Not to fussed about it being dual band, because I've had a dual band router that didn't work properly, and there was only one item in my house that could utilise the 5Ghz band.
mikko
I prefer to have 2 boxes - the modem by the socket near the front door and the router upstairs in a bedroom connected by homeplugs router to modem. That way i get wireless over the whole house from loft extension to downstairs rooms.
Works great, I get 71Mb/s through ethernet homeplug connections (not so much with wireless of course).
launton
Won't having a combined box cause DLM problems if people power down their boxes too often?
rongtw
Fixes: 12
Has PN not asked for testers of , i presume New combined router ?
