Recent fault.
peter10
Recent fault.
Had a broadband fault and Openreach engineer called on 16th Feb. He spent a while trying to find the fault and eventually traced it back to the exchange. It seems to be fixed now. Just like to say well done to both PN and Openreach for a fairly quick resolution.. Thanks.
1 REPLY 1
plusnettony
Fixes: 76
Re: Recent fault.
Thanks for posting this. I'm really pleased it's been sorted for you. I will pass on your thanks to the guys on our side that helped to sort it for you.
 Tony T
